![]() | Home > Technical (L322) > Reduced Engine Performance...AGAIN!!! |
| Jimwsmith Member Since: 25 Dec 2020 Location: Nottingham Posts: 1
Any news after swapping coil packs around , or fitting new ones ? |
| Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247
The codes have been concistent throughout
| dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3348
Have you checked using diagnostics to ensure that both lambda sensors are switching properly? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
No not yet. With the new exhaust syatem I am not sure if the sensors were re-employed or removed totally. The problem was before the new exhaust. The cats were 100% shot so it did need the new system. It will be something I will take a look at after I have done the coil packs.
If you plug in a decent diagnostics tool you should see the voltage of the O2 sensors jumping up and down proving they are working. If they're not working properly then the car will run like crap.
Cheers David
It'll be the same O2 sensor that's controlling that bank of cylinders so it's possible but I'm not confident enough to say either way.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
I have 4 coil packs to put on. Its my last option before I take it to a main dealer for them to empty my bank account.
Yes Martin Hind (think that is correct) in Dartford. That would be the option. It will stillcost but maybe half the price. There is a recall on the car needing to be done so would probably take it to MD to get that done and ask them to do a plugin once over and give me the report then head off to Dartford. Think there is a place in Rainham Essex too which is where I am. Cheers for the tips and info.
| Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929
I can vouch for dartford transmissions. Martin is very knowledgeable but also extremely fair. They have all the md tech and equipment so you'll be looked after. Mines showing the cams are over advanced by 1 degree. It's not using any extra fuel or anything but Martin diagnosed this and verified it with a load of advanced testing. He offered me two solutions, I can either have it all retimed, vanos doing etc or we can just map it out. Considering it's been like it for nearly 2 years now, I think I know what option to pick |
Soo......
Tbh that scanner won't give you all the faults mate so I'd say pop it over too Martin at dartford transmissions. I suspect he will come up with the fault pretty quickly. All I will say is he is very fair and honest with his prices and work. |
Will do. Is he a drive by have a chat type of guy or book in over the phone?
Normally drive in but given the current circumstances I'd call him on Monday and ask when martin can do a diagnostic test on it just so that both parties can abide by the current guidelines. He ain't just a plug and play guy, he will do extra tests with a lot of hand tools, multi meters etc to find the fault with the car. |
| All times are GMT |
