![]() | Home > Technical (L322) > FBH TD6 |
| kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 229
You have to have park heating (as its called) enabled in the ccf for it come up on the screen, mine is an 04 model and although had the FBH which comes on with engine when cold no option to set timer for it, the info on where it needs to enabled is on the Gap web site, I printed the info off and got Old Forge Garage here in Lincoln to enable it for me but just when you need it most my FBh has gone on strike ! |
| 24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 166
Out of interest then, how do you turn the FBH on if you dont have the option on the nav screen?
You cant turn it on unless the option is show`n on the screen, it comes on (or should) when the engine is cold to assist warm up on the diesel, I thought it was standard fit on td6 left hand wing below battery behind left front wheel splash guard maybe yours has stopped working normally you can hear it start up from cold. I had mine enabled so I could make it remote switch on using a Vellman wireless remote kit (range not as good as standard fit but good enough range for my needs) if you look in the engine bay left hand inner wing you should have couple of valves and a pump with pipe work going towards the bulkhead from FBH which will give you a clue if its fitted or not. |
Thanks kds2 - might have to have a poke about. 2010 L322 Autobiography Black Edition
| mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425
Thanks for the reply , I did enable it in the ID tool file but still no joy . Do you happen to have a copy of the GAP instructions that you could possibly post up on the forum please . |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
The GAP website has a full user manual.
Thanks , I did go through this but doesn't specifically say how to 'turn the heater function on' in the TD6 . I just says how to do a diagnostic and purge on page 124 if the system hasn't been used for a while . |
| stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 136
I remember bookmarking this some time ago ...
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
I did it on my TD6 when I had it, and I seem to remember having to do 2 things. Enable in CCF and then an instrument cluster reset I think.
https://www.fullfatrr.com/forum/topic14026...=park+heat
| mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99
To be honest - I had to google what an FBH actually was.
Well the car might well have an FBH, as of the old dear (wife I assume) only you can answer that one sir! |
We’ll when you put it like that, ill have to go and find out |
Has anyone found a working, non-LR alternative to the FBH pump for a TD6? The pump from the dealers is well over £100, whereas pumps that look the same are available for a fraction of that, such as https://www.amazon.co.uk/Universal-Meterin...08KXXVY43. Has anyone found one that is the right physical size, has the same wiring connector, and pumps at the correct rate? |
| All times are GMT |
