Home > Technical (L322) > FBH TD6
mercs600
England 2002 Range Rover Vogue Td6 Java Black
FBH TD6
I know the topic has been covered numerous times and despite searching through the forums I cannot see the answer to my question regarding the FBH fitted to my 52 plate TD6 Vogue. I can select time on/off etc but only for cold air . Can I change it to pre-heat the car as other vehicles ? I have looked through the menu on my IDtool but still unable to change it to hot/warm air ? Is it that on the early models it just aids cold temperature starts ?
Post #578378 4th Jan 2021 10:47am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
You have to have park heating (as its called) enabled in the ccf for it come up on the screen, mine is an 04 model and although had the FBH which comes on with engine when cold no option to set timer for it, the info on where it needs to enabled is on the Gap web site, I printed the info off and got Old Forge Garage here in Lincoln to enable it for me but just when you need it most my FBh has gone on strike ! Big Cry
Post #578459 4th Jan 2021 8:58pm
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Out of interest then, how do you turn the FBH on if you dont have the option on the nav screen?
I mean, presumably there would be a way to get it to come on manually? - If I knew it worked, I'd then investigate getting something to be able to edit the CCF files and enable it properly.
I must admit, I always thought our 03 Td6 was specified without it.
Neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #578466 4th Jan 2021 9:25pm
kds2
You cant turn it on unless the option is show`n on the screen, it comes on (or should) when the engine is cold to assist warm up on the diesel, I thought it was standard fit on td6 left hand wing below battery behind left front wheel splash guard maybe yours has stopped working normally you can hear it start up from cold. I had mine enabled so I could make it remote switch on using a Vellman wireless remote kit (range not as good as standard fit but good enough range for my needs) if you look in the engine bay left hand inner wing you should have couple of valves and a pump with pipe work going towards the bulkhead from FBH which will give you a clue if its fitted or not.
Post #578471 4th Jan 2021 10:13pm
24valve
Thanks kds2 - might have to have a poke about. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #578474 4th Jan 2021 10:39pm
mercs600
Thanks for the reply , I did enable it in the ID tool file but still no joy . Do you happen to have a copy of the GAP instructions that you could possibly post up on the forum please .
Post #578493 5th Jan 2021 8:37am
Weegie
The GAP website has a full user manual.
https://www.gap-diagnostic.com/support/documents/IIDTool/ John
GAP iiD BT-Sold
Post #578499 5th Jan 2021 10:33am
mercs600
Thanks , I did go through this but doesn't specifically say how to 'turn the heater function on' in the TD6 . I just says how to do a diagnostic and purge on page 124 if the system hasn't been used for a while .
Post #578505 5th Jan 2021 11:30am
stuart_2006
I remember bookmarking this some time ago ...
https://www.gap-diagnostic.com/avada_faq/h...park-heat/
Post #578553 5th Jan 2021 5:37pm
mjdronfield
I did it on my TD6 when I had it, and I seem to remember having to do 2 things. Enable in CCF and then an instrument cluster reset I think.
I’ll look for my post on here....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #578556 5th Jan 2021 6:15pm
mjdronfield
https://www.fullfatrr.com/forum/topic14026...=park+heat
https://www.fullfatrr.com/forum/topic13950...=park+heat
https://www.fullfatrr.com/forum/topic9101....=park+heat
Bit more here...
https://www.fullfatrr.com/forum/topic45058.html?highlight=heat 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #578559 5th Jan 2021 6:29pm
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
To be honest - I had to google what an FBH actually was.
So we are saying that my old dear has one of these somewhere, and I need to have some
some sort of remote, working thermostat Wink , enabled via OBD ?
To be fair I have noticed this car doesnt take too long to heat up compared to other diesels ive owned, i know some diesels have pre heaters that heat up the coolant going into heater matrix to heat up the cabin faster. Current Fleet
FF L322 2.9TD6 SE
BMW e46 330ci Msport
Skoda Superb TDI Mk2, stage 1
Audi A3 8P 2.0 T 4x4, stage 2
Yamaha R6 13S
Triumph Thruxton R
Sold, but not forgotten
WJ Jeep Grand Cherokee V8
Post #578948 8th Jan 2021 1:08am
kds2
Well the car might well have an FBH, as of the old dear (wife I assume) only you can answer that one sir!
Post #579016 8th Jan 2021 9:35pm
mazza7282
We’ll when you put it like that, ill have to go and find out Rolling with laughter Current Fleet
FF L322 2.9TD6 SE
Yamaha R6 13S
Triumph Thruxton R
Post #579019 8th Jan 2021 9:55pm
stuart_2006
Has anyone found a working, non-LR alternative to the FBH pump for a TD6? The pump from the dealers is well over £100, whereas pumps that look the same are available for a fraction of that, such as https://www.amazon.co.uk/Universal-Meterin...08KXXVY43. Has anyone found one that is the right physical size, has the same wiring connector, and pumps at the correct rate?
Post #601045 18th Jul 2021 1:43pm
