Home > Technical (L322) > Fuel Burning Heater Retrofit
Page 2 of 5 <12345>
Gsxr1250dave
Thanks for the offer Bristol is a bit far Very Happy my research suggests they work on either fuel I will be bench testing anything before I fit it. I all ready have a small fuel bottle to install in the engine bay to run it .......still waiting on the Ebay breaker to get back to me iv got everything else I need for the retro fit except the fbh Big Cry
Post #579023 8th Jan 2021 10:36pm
Gsxr1250dave
This post has been a great help
https://www.fullfatrr.com/forum/topic42186...petrol+fbh
Post #579024 8th Jan 2021 10:46pm
Dolphinboy
here ya go!
https://www.fullfatrr.com/forum/topic1024.html
https://www.fullfatrr.com/forum/post440480.html#440480
https://www.fullfatrr.com/forum/post368302.html#368302
https://www.fullfatrr.com/forum/post416143.html#416143
https://www.fullfatrr.com/forum/post126007.html#126007
UK Based PCB Repairer - Paramount Electronics in Aylesbury.
http://www.paramountelectronics.co.uk/
Did a first class repair job for both a 1991 VW Westfalia Camper Van domestic electrics PCB and also a lighting control PCB at work that second hand was �700! Both cost �100 each approx IIRC
Post #579027 8th Jan 2021 10:58pm
Gsxr1250dave
Thanks for the links great bit of reading....gonna take my battery out and battery tray and just make sure there isnt a fbh under there . It's easy to get confused. Iv got park heating and have set it and seen it come on and off but only blowing cold air.........now where did I read all L322 with park heating have a fbh ? I need another glass of Jura
Bow down Bow down many thanks
Post #579029 8th Jan 2021 11:24pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I think that I may have to give it a miss, as checked my display screen & no timer available. Therefore although I have the wiring for a FBH. I guess there's a lot more electronics involved.
Edit:- Just read that this can be activated by diagnostic tool, so may be back on Thumbs Up
Post #579066 9th Jan 2021 12:47pm
Gsxr1250dave
My retro fit will be activated by remote so dont worry I can supply what you need once iv got mine sorted, I just happen to have the timer on my car but no fbh.
I didnt rearly think it did as I know my car pretty well but just for fun iv pulled the battery tray out for a look see
Post #579080 9th Jan 2021 1:54pm
Highroller
Thanks for the help Dave. These are the connections that appear spare on mine. The engine one is grey with a black tracer & Brown with a black tracer.
Trying to see if your connection is the same?. Paul.
Post #579087 9th Jan 2021 2:43pm
Danwilderspin
Mattstevenson did a diy on this years ago it’s a massive ballache Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #579387 11th Jan 2021 11:04pm
Gsxr1250dave
So far I dont see much of an issue my Ebay seller has removed everything off a td6 for me that's attached to the fbh. And he has a video for me of routing all the hoses if I want it.
As it will most likley be a stand alone unit independent of the car turning it on and I want it to warm up both the engine and the hevac it should be plug and play.
My intention is to connect it inline with my lpg vaporiser hose as this time of year it doesn't like switching over in such cold temps. I have to run it a good 20 mins on petrol before it's all heated up enough to work.
It will have a 15 min timer on it so I dont forget to turn it off or flatten the battery which is new.
All the plugs are there I will check to see if any power up when the aux ventilation powers up.
Post #579388 11th Jan 2021 11:17pm
GrunterNI
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
Having spent last weekend under the fFNS wheel arch trying to sort mine I reckon retrofitting one of these would be an absolute ball ache and is just going to be something else to go wrong.
As mine, like so many others, pumps out clouds of stinking smoke and takes ages to actually heat the interior whilst giving the nice new battery a good hammering in the heating process I decided that the best course of action was to pull its fuse for posterity and forget about it. What sealed it for mine was that during two really cold nights we had recently it came on whilst I was driving and also whilst sitting stopped at traffic lights, much to the concern of the drivers around me with faces like Shocked and the fumes made my interior reek of diesel fumes. Not impressed!!
The problem with them is that they were designed for use in leisure vehicles where they run for hours on a timer and are thermostatically controlled to give continual warmth, not just for thirty minutes to pre heat our lovely interiors, plus in the UK we dont live in a cold enough climate for them to function as LR intended which is why the burner clogs up so badly and the unit starts to blow clouds of smoke, burns irregularly and triggers faults.
The concept was good but as so often is the case, the practical reality not so good. Current collection :
2007 Vogue TDV8 Stornoway grey, black on black
1982 JCB Sitemaster (resto)
1970 MGB
BMW R1200GS
Post #579684 14th Jan 2021 12:40am
Gsxr1250dave
I completely get it but, having sorted the fbh on the wifes D3 it has been a god send just recently. As we can turn it on and off at will using a remote we can warm the car up a good 20 mins before we use it.
As my l322 is a v8 petrol the factory fbh was only meant to warm the interior using the on board screen to programme it my intention is to just use a remote to warm both the engine and interior. I will carry out some tests tho just to see if the car will activate it or not.
The Ebay breaker has posted everything I asked him for and more I will run it all up on the work bench to ensure it's all working as it should then plumb it into the car.
Iv had some very helpfull posts on this sent to me by others on here let's see if I can get it to work
Post #579685 14th Jan 2021 12:52am
dhallworth
Am following your progress with interest as I fancy this on mine too.
D 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #579686 14th Jan 2021 12:59am
GrunterNI
When I took the plunge and bought my motor I was telling my wife (ahem, boasting) all about how it would be lovely and toasty warm and completely defrosted in the colder mornings, then it went and let me down and we thought it had caught fire because of all the blooming smoke the first time I activated it Laughing
I'll follow your progress and look forward to seeing the hopefully toasty end result.
Good luck Current collection :
1970 MGB
BMW R1200GS
Post #579721 14th Jan 2021 11:15am
Gsxr1250dave
Big box of fbh stuff arrived today
Post #579913 15th Jan 2021 8:25pm
Gsxr1250dave
Opened my box of goodies as iv now got everything I need todo my retrofit, fuel pump and electrical connectors n plugs all arrived.
So what's in the big box ?? Everything I asked for and more.
I'm going to rig all this up on the bench first to ensure it all works as it should then set a bit of time aside to fit it and plump it all into the car.
Post #580247 18th Jan 2021 1:39pm
Page 2 of 5 <12345>
