Home > Technical (L322) > Rotary gear knob owners - help please |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
On mine, it raises when the engine is started 2017 4.4 SDV8 Autobiography
13th Jan 2021 11:36am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Thanks, that was quick
13th Jan 2021 11:43am |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
Mine doesn't raise until the engine starts, if I press the start/stop button with my foot off the brake pedal, the dash lights up but the rotary gear selector stays down 2011 TDV8 Vogue SE |
13th Jan 2021 1:10pm |
Yep, same here. 2017 4.4 SDV8 Autobiography
13th Jan 2021 4:06pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
Mines the same, does not raise until engine starts. Geoff |
13th Jan 2021 4:25pm |
Thank you all, you’ve confirmed that mine does what it’s supposed to do, I had convinced myself that it should rise as soon as the ignition is on.
13th Jan 2021 11:45pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2971 |
What is your intermittent fault?
14th Jan 2021 12:02am |
That’s interesting about 3 starters in 23K miles. Mine started with the classic occasional click and having to press the button a second time a few weeks ago but at 10 year old and over 100K miles I can’t complain. I bought a new Denso 1217 and fitted it a few days ago, all was well for a couple of days (and many starts) until it decided on Tuesday to not start no matter how many times I press the button.
14th Jan 2021 5:57am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4220 |
I've seen a thread on here about the cable from battery to starter being made up of 4 separate "bits". The person replaced it with one new lead.
14th Jan 2021 9:16am |
That's pretty much what I'm looking at by trying to eliminate problems, trouble is it has worked perfectly today so I can't find a problem that's not there.
14th Jan 2021 6:08pm |
jackconcord Member Since: 04 May 2018 Location: Bothwell Posts: 5 |
Looks like this might be a common problem. I just posted a question on the same subject a few minutes ago. Intermittent starter engaging. Mine is a 2011 322 with 75k miles. |
17th Jan 2021 6:23pm |
