![]() | Home > Technical (L322) > Rotary gear knob owners - help please |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1056 ![]() ![]() ![]() |
On mine, it raises when the engine is started 2012 Westminster |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 306 ![]() ![]() ![]() |
Thanks, that was quick
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 254 ![]() ![]() ![]() |
Mine doesn't raise until the engine starts, if I press the start/stop button with my foot off the brake pedal, the dash lights up but the rotary gear selector stays down 2011 TDV8 Vogue SE |
Yep, same here. 2012 Westminster |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3072 ![]() ![]() ![]() |
Mines the same, does not raise until engine starts. Geoff |
Thank you all, you’ve confirmed that mine does what it’s supposed to do, I had convinced myself that it should rise as soon as the ignition is on.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 923 ![]() ![]() ![]() |
What is your intermittent fault?
That’s interesting about 3 starters in 23K miles. Mine started with the classic occasional click and having to press the button a second time a few weeks ago but at 10 year old and over 100K miles I can’t complain. I bought a new Denso 1217 and fitted it a few days ago, all was well for a couple of days (and many starts) until it decided on Tuesday to not start no matter how many times I press the button.
DrRob Member Since: 16 Apr 2015 Location: Hampshire Posts: 2302 ![]() ![]() ![]() |
I've seen a thread on here about the cable from battery to starter being made up of 4 separate "bits". The person replaced it with one new lead.
That's pretty much what I'm looking at by trying to eliminate problems, trouble is it has worked perfectly today so I can't find a problem that's not there.
Site Copyright © 2006-2021 Futuranet Ltd & Martin Lewis
