![]() | Home > In Car Electronics (L322) > TV channel stuck on Sky News! 2010 Supercharged |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
Don’t want to cast any more uncertainty.... cos I’m not sure on this, but if the unit isn’t new and come out of another L322 I would imagine it shouldn’t need config. Happy to be corrected... just using logic....
wpo750 Member Since: 17 Nov 2018 Location: London Posts: 32 ![]() ![]() ![]() |
Agreed, I just checked the CCF with the GAP tool and they are correct. Hybrid tuner, Variant 1, analogue/digital. I'm not sure what else those instructions could mean regarding configuration.
I can’t think of anything else that would cause the tune option to not work.... if it’s an antenna issue, would it not still tune and then not find anything?
Just to add, for what it's worth, with either tuner module installed I'm unable to select any other country in the settings. The countries are all listed but pressing on them does nothing.
Just to update this. I've tried three separate tuners now and the same problem persists. Each one manages to give one perfectly tuned channel (Channel 5 with most recent tuner) but with no option to change channel and no suggestions on auto.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
coincidently i got this 'one station only' the other day...turned out to be the location i was in..
Hey Stan, I have indeed tried different locations but to no avail. Relatively trivial issue this TV thing but really rather annoying that it doesn't work properly. Is there a way to refresh or update the firmware on these systems do you know? |
i've not heard of anything like that..normally a tuner module change solves problems.. ... - .- -.
