Home > Technical (L322) > Alternator or battery?
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
The saga continues......battery removed and retested....showed as perfect! Garage had charged it while in the vehicle when fitting replacement brake discs and pads. Replacement battery fitted so not any further forward. I’ll get the alternator tested by an auto electrician....thanks for all contributions Thumbs Up
Post #579792 14th Jan 2021 9:24pm
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
Did you get to the bottom of this?
Post #580972 24th Jan 2021 6:41pm
kgeddes
Checked battery/charging today.
Engine on figures are with all lights on and full demist program running.
Do results appear ok?
Post #580993 24th Jan 2021 9:01pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
The minimum with engine running is too low unless it was a glitch, you need to check that one again. Run the check after starting. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #580996 24th Jan 2021 9:24pm
kgeddes
Thank you, I’ll try it again. I think this reading was taken as I started the engine....
Post #581099 25th Jan 2021 3:06pm
As I recall, the voltage remains around 13.8V after startup for a few minutes and should them rise to over 14V, as the alternator starts to charge the battery, once all the electronics have settled down. Got - 2017 SDV8 Autobiography in Loire Blue
Post #581108 25th Jan 2021 4:36pm
kgeddes
I’ve been monitoring the alternator and battery and while the alternator is charging at 14.7 - 14.9 the new battery never reaches above 12.3V. For example, on Sunday I checked the battery reading at 12.2V, I then drove for an hour and a half but when I rechecked the battery it read 12.3V.
Is it possible that the alternator is not allowing the battery to fully charge?
The new battery is also draining by between 0.1V and 0.3V overnight....
Any help gratefully received Thumbs Up
Post #582932 9th Feb 2021 11:55am
kgeddes
Auto electrician has traced the battery drain to fuse 49. Specific component still to be identified (probably satnav unit). Replacement battery and alternator probably never required! Evil or Very Mad
Post #592154 22nd Apr 2021 8:18pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Battery on L322s are always a pain. Censored
Two positives to take from this:
Your current drain located, if not yet identified
Alternator/Battery replacement would have raised their head at some stage anyway, so at least they are out of the way.
If used every day and a new battery fitted every year, no problems.
Standard testing during development? Not reflective of typical use after warranty.
I have a voltage logger fitted to mine. Sometimes drops 12% between 2 and 5 in the morning. (FSR changed just in case)
Other times can be left 6 weeks and under 5% drop. Bizarre ! (perhaps I am too old for all this)
Personal view is over enthusiastic software. Shut the doors, press lock, alarm on, EVERYTHING ELSE OFF - Simples !
My goodness, the torque from 4.4 TDV8 is staggering. Almost makes their foibles worth it.
No such probs with the '72 Very Happy Thumbs Up Forty years of progress. 1972-2012
Post #592988 2nd May 2021 10:29pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
New battery every year😲! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #593023 3rd May 2021 9:33am
Arbuckle
appj62
New battery every year ? Sorry - Tongue in cheek comment - couldn't resist. Rolling with laughter
I find it hard to believe that Land Rover, BMW, Ford whoever, never had similar battery problems during development. Whistle Whistle
Hence, maybe they always put new batteries in. Duracell perhaps?
All my electrics work, not necessarily at the same time though. Love my FFRR Forty years of progress. 1972-2012
Post #593156 4th May 2021 6:27pm
