Home > Technical (L322) > Alternator or battery? |
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 |
Did you get to the bottom of this? |
24th Jan 2021 6:41pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Checked battery/charging today.
24th Jan 2021 9:01pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
The minimum with engine running is too low unless it was a glitch, you need to check that one again. Run the check after starting. BMW i3 Electric Car
24th Jan 2021 9:24pm |
Thank you, I’ll try it again. I think this reading was taken as I started the engine.... |
25th Jan 2021 3:06pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
As I recall, the voltage remains around 13.8V after startup for a few minutes and should them rise to over 14V, as the alternator starts to charge the battery, once all the electronics have settled down. Got - 2017 SDV8 Autobiography in Loire Blue
25th Jan 2021 4:36pm |
I’ve been monitoring the alternator and battery and while the alternator is charging at 14.7 - 14.9 the new battery never reaches above 12.3V. For example, on Sunday I checked the battery reading at 12.2V, I then drove for an hour and a half but when I rechecked the battery it read 12.3V.
9th Feb 2021 11:55am |
Auto electrician has traced the battery drain to fuse 49. Specific component still to be identified (probably satnav unit). Replacement battery and alternator probably never required! |
22nd Apr 2021 8:18pm |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 |
Battery on L322s are always a pain.
2nd May 2021 10:29pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
New battery every year😲! Previous cars:
3rd May 2021 9:33am |
appj62
4th May 2021 6:27pm |
