Home > Technical (L322) > Reduced Engine Performance...AGAIN!!!
Page 9 of 28 <123 ... 8910 ... 262728>
Ashmyster79
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Again agree with what you are saying. They could have kust given it back in all fairness they are under no obligation etc. I appreciate the work just maybe the comms has been minimal and confusing but maybe thats my issue. Im a bit simple its either balck or white is or isnt. Guess there is the middle ground I need to respect. Current Cars
L405 Range Rover Vogue 4.4 Diesel
Previous cars
Lamborghini Gallardo
2006 Range Rover Vogue 4.2 V8 Supercharged Petrol
1996 Williams Clio 2
Aston Martin V8 Vantage
Bentley GT Continental
Porsche Cayenne 4.5s
4.2 V8 Supercharged Range Rover
Porsche Boxster 3.2s
Ford Kuga
Nissan 350z
BMW 316
Porsche Boxster 2.5s
Golf 2.8 VR6 Highline
Renault Clio 16v
Vauxhall Nova GTE
Post #580877 23rd Jan 2021 7:16pm
Ashmyster79
**UPDATE UPDATE**
Just had an email through from Martin. Anyone break this down in to simpleton format ๐Ÿ˜Š๐Ÿ˜Š๐Ÿ˜Š
Ok, with all the tests we have carried out, I am almost certain that the camshaft timing on Bank1 is atleast 1 tooth out. The ignition timing appears to be atleast 54Degrees retarded, The following oscilloscope waveform Shows that the Ignition coil trigger (Green) is occurring well before the peak Cylinder pressure (yellow) and this should be happening almost simultaneously with large gap on the Crankshaft sensor (Blue)
Unfortunately, this is as far as electronic diagnosis will let us go, and therefore we will need authorisation from you to remove the rocker cover on that bank and mechanically check the camshaft timing, please keep an eye out in your inbox for an estimate to do this.
So what does this graph mean?
Rocket cover is that just the engine tops?
 Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581297 26th Jan 2021 9:15pm
dhallworth
The rocker cover is the valve cover on the top of that cylinder head. Removing it will allow them access to the timing gears for that cylinder head.
They will be able to check if everything is timed properly by pinning the crankshaft where the crankshaft position sensor would normally live and checking that the timing on that particular bank is correct.
Post #581299 26th Jan 2021 9:19pm
Ashmyster79
Actually just re-read it. So yellow and green spikes should overlap and trigger at same time but they are out of sync do would need realignment?? Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581300 26th Jan 2021 9:20pm
Ashmyster79
Ok makes sense. Is that a big job to remove the rocker cover. Will this need new gasgets etc? Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581301 26th Jan 2021 9:21pm
Ashmyster79
**Another update**
Pics attached in a nutshell ยฃ720 to fix we hope ๐Ÿ™ˆ๐Ÿ™ˆ
 Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581302 26th Jan 2021 9:27pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Least you've managed too get an answer on it mate unlike the others.
From what I can under stand, the green, yellow and blue should all be in line with each other to create its peak performance level so if the timing is 1 tooth out its going to be out of line creating the peak performance power hence the miss fire as its not at its happy stage if that makes sense
Post #581307 26th Jan 2021 9:57pm
Ashmyster79
Yes totally get it. How would it go out of line? Age/time or someone sickikg about with it like the previous owner?
Price wise I dont have much choice. Cars been gone quite a while now. Forgot I owned it. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581308 26th Jan 2021 9:59pm
Bean19844
Could be if someone done the chain and didn't time it properly. Could have happened if the chain was worn out and jumped a tooth. Always a thousand reasons why it could have happened I guess. Its upto you mate what you do going forward. Only thing I would say tho is just stick with the one garage for stuff you cant do yourself. Martin might not be the cheapest but you pay for more with martin then a plug and go jobbie with most garages. You'll love it tho when you get the car back and you can hear the charger scream with power
Post #581311 26th Jan 2021 10:11pm
Ashmyster79
I have given martin the go ahead. It is probably more than I wanted to pay but you are right. I took it to a garage whenI first bought it and paid ยฃ1050 and think now I probably overpaid anddidnt need an item or 3.
Lets see how it is when I get it back. Hooefully this week.
I had my Bentley GT for 3 years not a thing went wrong with it although the annual service was ยฃ800 ๐Ÿ™ˆ. Guess no matter what car you own it will cost.
I will update once I have more news. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581314 26th Jan 2021 10:20pm
DrRob
I knew Martin would come up trumps Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #581315 26th Jan 2021 10:23pm
Ashmyster79
Might explain the rattles of nder the bonnet too just hope that is it and nothing else is unearthed upon taking the rocker cover off Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581316 26th Jan 2021 10:26pm
dhallworth
At least youโ€™re heading in the right direction.
If youโ€™re getting a rattling from under the bonnet, it might be worth asking Martin to run it with the supercharger belt disconnected as Iโ€™ve done that with mine and found the supercharger is the source of my rattle, not the engine.
Post #581318 26th Jan 2021 11:11pm
dingg1
If its jumped a tooth the likelihood is that the timing chains, are stretched and need replacing, hopefully someone has already done them and made an arse of it....
Post #581319 26th Jan 2021 11:14pm
Ashmyster79
Two arses here.....one who sold it and one who bought it!!! Laughing Laughing Laughing
Going by who sold it I would say they made a pig's ear of it. Hopefully, nothing else is needed as I don't want to keep shelling out on it.
Will keep all updated. Current Cars
Previous cars
Ford Kuga
Nissan 350z
BMW 316
Renault Clio 16v
Vauxhall Nova GTE
Post #581330 27th Jan 2021 10:05am
