Home > Maintenance & Mods (L405) > Just in time for winter...remote climate retrofit
Page 3 of 8 <12345678>
knwatkins
dolph34 wrote:
I did this on my 2007 but had to fit an aerial for the receiver. All the other wiring was there but no aerial.
On the L405, the antenna port from the receiver module connects into the television antenna amplifier module also located on the base of the D pillar. The receiver therefore uses the television antenna built into the rearmost offside window and does not have a separate one, unlike the L322, L319 and L320. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #569589 12th Oct 2020 10:07am
Phil.
Mines a MY19 SDV8 VSE. Is that the FBH piping in the photo?
 MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #569628 12th Oct 2020 3:04pm
knwatkins
Yes. Yours is a Webasto unit. Land Rover must have changed back to Webasto for the later L405s. Kev
Post #569631 12th Oct 2020 3:31pm
Phil.
Many thanks.
Do you know if the part no. for the receiver is the same as the one you posted earlier? MY23 D350 HSE
Post #569632 12th Oct 2020 3:35pm
knwatkins
It'll be different, Phil. The part number earlier was for the Eberspächer receiver.
I have a Webasto receiver that was installed on a previous generation vehicle but I'm not sure if it will be compatible with a new one. I doubt it to be honest. Kev
Post #569634 12th Oct 2020 3:46pm
Phil.
I’ve located the part number(s) on the FBH unit, any idea how to find out which receiver to match it with? Might it be one of these?
https://www.ebay.co.uk/itm/for-LAND-RANGE-...Swcj5ZQ~Sj
Webasto Thermo Top Evo Part no. 9033499B
Land Rover JPLA-18K463-DA (9033957B) MY23 D350 HSE
Post #569647 12th Oct 2020 6:29pm
knwatkins
Hi Phil, I'm not sure to be honest. That receiver you linked to is the same as the one I had installed in my 2010 RRS and also fits in the L319 and L322.
I think that on the newer models, the remote climate is controlled through the InControl app.
Edit: I see that the InControl app starts the engine, FBH is still via the separate remote.
Have you checked to see if you have the wiring for the receiver at the base of the D pillar? It would be good to have a picture of the connector. Kev
Post #569692 13th Oct 2020 1:04pm
Phil.
Thanks Kev,
I checked this morning and think I am out of luck. I had a good feel around behind the insulation but couldn't find anything that looked like of the sort of connector I would need for a receiver or an antenna.
I might have to invest in a GAP tool and see if I can get the timed FBH working.
 MY23 D350 HSE
Post #569698 13th Oct 2020 2:36pm
knwatkins
Where the BCM is on the right of your picture, you need to look/feel upwards into the D pillar. Kev
Post #569705 13th Oct 2020 3:27pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Dolphinboy wrote:
Horse you can get petrol FBH- I have it on my 2004 petrol V8. It’s a webasto. I’m sure you could get one your side.
knwatkins wrote:
Remember the L405 does not use a Webasto FBH. It uses Eberspächer.
Eberspächer may have something though.
So is this not doable on the petrol L405? on the 2004 did you have to install the ducting etc to push the air into the cabin? As well as the module and the remote + coding? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #569706 13th Oct 2020 3:37pm
Phil.
This is the view up the D Pillar. A single large loom with a spur off for an interior boot light and also the small green box. Nothing else loose or taped as far as I can tell.
 MY23 D350 HSE
Post #569711 13th Oct 2020 3:50pm
knwatkins
The existing heating ducts and climate control is used. You have no FBH so you have to see if you can install one. Kev
Post #569715 13th Oct 2020 4:03pm
horse86
^^ I can't believe no one owning an l405 petrol hasn't tried installing this....I've literally found nothing on the internet. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #569731 13th Oct 2020 7:05pm
capcgn
Germany 2006 Range Rover Westminster 4.4 V8 Chawton White
216 L405 SDV8 European car
I tried to retrofit the remoute unit on my car. I have the heater ( exact as it is shown in the pictures) under the bonnet. But I dont have the cable under the rigth rear pillar. Instead I have a small loom what is connected to a TV unit ( antenna) and the boot lamp. I think the location for the remoute ECU has changed. Could one of you check if this is the case for the 2016 or LR has eliminated the loom to connect the remoute ECU and the antenna cable ? It would be great, I have now all needet parts and the ID tool and cant install the parts. Thanks in advance.
Post #581331 27th Jan 2021 10:06am
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
HI
When I found the connector they where fully covered with black cloth tape and attached the antenna cables , you could not see the connectors at all I just felt a lump which I unwrapped .
Post #581332 27th Jan 2021 10:16am
