![]() | Home > Technical (L322) > Reduced Engine Performance...AGAIN!!! |
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 243 ![]() ![]() ![]() |
Wasnt the way you were driving then |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
Where did you buy the car from? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
I didn't have no talent back then to drive it quick without stuffing it into a kerb.
Yes normally it is a plug in and diagnostics then fix the issue. This is a bit more indepth. Only concern is it went from £88 to £720 quite quickly. Was expecting around the £500 mark Current Cars
Oh the dreaded ebay. Was hoping for a bargain!!! Current Cars
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
The hourly rate is generally the killer on garage bills but sometimes it's necessary to use them, especially with the issue you seem to be having at the moment. It does look as though Martin is doing an honest job and is giving you as much information as he can. From other responses on here it seems that he runs a trusted garage, and as you have found out to your cost already, these can sometimes be hard to find. Personally I would take some comfort in that |
Oh yes hence me authorising the work to be done. It is a lot but it isnt if that makes sense. Seems more because of the wasted money previously. The amount isnt so extreme but the money wasted before is the killer.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
Ash i think Martin has done you proud there to be honest! i know the comms have not been great and frustrated you hell i have been chewing wood on your behalf!! but i do not know many garages that are capable of carrying out that kind of diagnostics let alone interpreting the results on the oscilloscope.
The waveform helped. I would hazard a guess previous ownertried to do some work on it. Left some bits off or disnt put it back correctly. Started having issues so offloaded it. Thats my gut feel.
Do I assume no work has been done on the car for a week??? Strange no progress on the car simce rhe last update Tuesday. Apparently tomorrow its being worked on
It’s not going to be a 5 minute job and it’ll be taking up space on a ramp whilst they strip it down. If they’ve been fully booked they might not have had time/space or an available mechanic to strip it.
I thought it was on the ramp being worked on when they messaged tuesday with the needed fixes. I must have miss understood. Tomorrow apparently so hopefully by next Friday should have it back. Yes I gather it wont be a day job Current Cars
Gotta remember mate, it was only in for diagnosis initially so would then be booked in to be worked on. No reputable garages ever tell you yep bring it down now and we will start on it straight away. Only the crap ones do that as they don't have a good customer quantity so generally sitting around doing nothing in the first place |
Ah yes true. I can take it to a guy and he will work on it that day or the next. But not big jobs. Makes sense. I thought it was being worked on when they found the issue. Car will be gone nearly a month. Sisnt think that when I dropped it off ha🙈🙈 Current Cars
