![]() | Home > Technical (L322) > Fixed - Multiple lights and faults on the way home |
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 ![]() ![]() |
Fingers crossed for you Graham 2011 Vogue SE Tdv8 FFRR |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88 ![]() ![]() ![]() |
Thanks Mike, fingers crossed. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
On the later L322's you really have to use the designated JLR diagnostics to locate issues, they can read to a much deeper level than any other including Snap-On etc
The garage uses Autologic, and I ran the JLR version of icarsoft. The both said the same thing. I instructed the garage to send the unit for testing as a precaution. |
The repair company has said they abs module has passed. The garage stuck it back on and the errors cam back straight away.
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Following, as I've been there too.
Do you think the Gap tool will tell you more than the Autologic that the garage has or the icarsoft unit I have used? I have read a load of stuff on this type of fault and it appears it could be a number of things. I had noticed before the car was collected that the steering sensor was showing a crazy angle on the icarsoft tool, I have told them this, however, like most professionals you never believe the customer.
So it’s still in the garage but the mechanic is back. They plugged the abs unit back in and the errors popped back up. They have noticed that the voltage to the fuses drops to 10v when the unit is plugged in but they show 12v when it isn’t.
So the garage has emailed, looks like a wiring fault. |
They have fixed it there was a open short on one of the wires. They have it this out and replace it so it looks like it’s all good I should get the car back today. |
Glad it's fixed, do you know how/wire the wire was damaged and shorted and where it was..? Pete
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
one of the wires on the connector for the ABS module?
To be honest I’m not actually sure which wire, I have a lot on and those things have been a higher priority in my life.
So the brakes definitely have air in them. The garage replied that the feed and Earth wire from main fuse box to ECU that had repair.
