![]() | Home > My Range Rover > 200k 04 Autobiography and 75k 65 VogueSE |
| nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560
So a quick update on this - the VSE has been running pretty well the last few weeks - seems to be ever such a slight misfire at cold on low revs for a very short period of time - possibly an injector on the way out and was going to book it back in when the Welsh firebreak is over but........
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872
thats kinda good news then |
November 2020 - 200,497
Hey Tom - its going well at the moment although with lockdown 3, not getting much use at all really. Its up to 200,700 miles and has done a little trailer towing to get hay bales recently.
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3278
Nick, I got the same intermittent loss of power steering on my 2004. It was the BCU (under the Pax seat) gone wrong. It also then later stopped my rear pax door from unlocking. It can cause various things. Ay be worth checking before you go down the PAS pipes route?
Sounds good mate - thanks. Will check that out. Easy enough to change with the Gap tool?
| TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107
Great to hear the AB LE has hit 200,000 miles nicksaab. Hats off to you and your mechanic for getting it there.
Hey Tom - been there done that, had a 2012 Westminster before the 405 which was the intention to do the same, but then the L405 came along a bit earlier than expected. I may go back to a 322 but it will more than likely be another 405. Fortunately the man maths don't need too much encouragement.
Huge thanks nicksaab. I’ll put a post in the forum to get a couple more measurements from a couple more early L322s, so I definitely get it right next time. 2004 L322 4.4 V8 Vogue Bonatti Grey
April 2021 - 201,722
July 2021 - 203,644
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Excellent news on the MOT and not too bad considering the mileage... |
Great update on the LE nicksaab! Great to hear that you’ve had it back on frontline M4 service. But it has meant my plan to overtake you on the miles has floundered- my 2004 is lagging around 202,500. Note to self, must try harder!
July 2021 203,737
