Home > Technical (L322) > 4.2 SC lean codes
Page 10 of 12 <123 ... 9 101112>
mgrover
another update, i managed to replace the precat bank 1 lambda sensor. much easier to get to than bank 2. reset the adaptations and relearning atm. we'll see how it goes.
also do not buy these sensors from anywhere except the dealership. euro carparts gave me the wrong one and the car was basically beached for 2 days till LR managed to get some in stock since I did the change Sunday and by time i realised my problem parts department were closed.
i still had 12.5% long term fuel trim in park at idle before the adaptation clearing so we'll see what this does. everything points to a vacuum leak but smoke test shows nothing.
am sure eventually it will trigger a lean code but it does it so slowly it feels like that its a really small leak. some also say it could be the cats. Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #565436 25th Aug 2020 11:42am
Danwilderspin
wouldn't mess about with it until you can do the other sensor.
You can get them from other places they are just dense specific sensors - I ordered mine from the US I think they were £100 that way and are fine - identical to the old ones I pulled. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #565439 25th Aug 2020 11:55am
mgrover
ive got both sensors with me, its just bank 2 is an absolute monster to get to. this would also provide a clearer picture if the new sensor has made a diff, because i can compare bank 1 vs bank 2 directly then, new vs old. Its actually a sport Sad
Post #565440 25th Aug 2020 12:01pm
mgrover
I think I hate this car.
My trims are still bad haha. All pure petrol, since my last post I swapped the piping at the back of the charger, rebuilt the manifold atleast twice. Changed the fuel filter and fuel pump. Fuel injectors cleaned and seals replaced
All gaskets replaced with above, I now finally have adaptive fuel trims to look at
Anyone any ideas? Before you say vacuum leak I've smoke tested the Censored out this engine Its actually a sport Sad
Post #583294 11th Feb 2021 9:07pm
dingg1
Is it popping up lean codes?
Post #583298 11th Feb 2021 9:49pm
Danwilderspin
Have you some coils and o2 and genuine maf? If not do them all for one bank and see if any improvement? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583309 12th Feb 2021 12:13am
Danwilderspin
Also I’d join a Jaguar forum for specialist issues like this a popular one as our engine has many many applications and a far bigger user base in these - obviously feed back on here if they help you Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583311 12th Feb 2021 12:14am
mgrover
It's not, the worst trim there is 17% and lean codes start at 20%
Everything but the coils, but I'd assume if there was a problem in combustion the subfeedback would show it.
I did actually check the jaguar forums here:
https://www.jaguarforums.com/forum/general...760/page2/
am literally outta ideas tbh. i wouldn't even mind taking her to a mechanic but people see the lpg and get scared off very quickly. Its actually a sport Sad
Post #583336 12th Feb 2021 10:21am
dingg1
If it aint popping codes you are worried about nothing, just drive and enjoy.
The control system is capable of keeping within the safe parameters...
Post #583338 12th Feb 2021 10:29am
Danwilderspin
If you are driving it on petrol Dingg is probably right but if you'd like to drive it on gas id want those a bit lower, I was getting rich codes with bad coils actually so that won't be your issue.
TBH mine is not perfect I don't think they are ever going to sit at 0 on both trims, id be interested to know what your idle is like from cold? mine is sometimes not quite as silky smooth when its cold as it usually is... seems to be a few on here that have the same thing,,, Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583342 12th Feb 2021 10:48am
mgrover
from cold its actually pretty banging. smooth, no issues. but yeah I do want to run her on gas which is why am trying to fix the trims. Its actually a sport Sad
Post #583343 12th Feb 2021 10:49am
dingg1
Do you get lean codes when its running on gas?
Post #583345 12th Feb 2021 11:11am
mgrover
It will do yes, the gas pushes the trims too far Its actually a sport Sad
Post #583351 12th Feb 2021 11:49am
Danwilderspin
fair enough mine are floating around 5-10 last time I looked and I was happy as like ding said these aren't highly refined engines they are big brutes they are never going to be bang on... id love it to be 0 but I think my quest would cost a fortune and would make it one of the only ones Smile Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583354 12th Feb 2021 12:10pm
mgrover
id be happy with 5-10, but 17 is ridic Its actually a sport Sad
Post #583357 12th Feb 2021 12:14pm
