![]() | Home > In Car Electronics (L322) > Headunit Upgrade on 2006-2010 - Work in progress |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2299
Just an update - Erisin said it was on a bad firmware updated it and touch wood everything is working as it should....
| WellDrivenJames Member Since: 03 Feb 2020 Location: Cambridgeshire Posts: 44
Just to clarify with this, I've got a 2004 Vogue - If I fitted one of these with the 5m cable etc would I retain steering wheel controls? Thanks |
Yes that's correct
Perfect, thank you!
Yes the only thing is it’s for an e53 x5 so it has a slight curve to it oem doesnt- this doesn’t not bother me but I can send a pic if needed.
Thanks!
Here is a pic:
| MarkNL Member Since: 26 Jan 2014 Location: utrecht Posts: 46
Hi Dan
No dvd as that is not in the new head unit.
| BVX Member Since: 19 May 2021 Location: Florida Posts: 1
Hi guys. Can someone give me a list of things to buy for an upgrade |
Are you wanting to change the amp too? I personally would as it’s easier and sounds great on the stock speakers believe it or not Current stable:
Just to bring this one up again (my apologies) - my DSP seems to be no more, does It need to be working for sound to work with these units or do they bypass the need for the amp? '04 Adriatic Blue Td6 Vogue Previous - '96 P38 DSE, '07 D3 HSE, '09 FL2 HSE, '00 FL1 (and many non-LR cars over the years!) |
Good question- you can either join all the word together for each door from the amp plug and connect them to the headunit or run an external amp which is do so as not to overload the headunit.
| Synfinite Member Since: 30 Aug 2021 Location: BC Posts: 3
Old thread but:
| All times are GMT |
