Home > In Car Electronics (L322) > Headunit Upgrade on 2006-2010 - Work in progress
Page 3 of 3 <123
TDV8 Paul
Love this idea, I’ve got a vogue se and I’m worried I’ll lose the rear screens if I did this, would that be the case? 2007 TDV8 Vogue SE
2005 BMW E63 645ci
2009 5.0 Supercharged autobiography
2024 Porsche Macan
Post #580421 19th Jan 2021 12:47pm
Danwilderspin
Just an update - Erisin said it was on a bad firmware updated it and touch wood everything is working as it should....
Next upgrade may be door speakers and aftermarket amp now I can do this but will stick as it is for the time being...
With regard to losing the rear screens yes you would - I had a smashed one anyway and an intermittent dvd changer so it was pretty useless in mine as it was. could with that I got a late 2012 AB interior which looks the mutts nuts but that did not have screens so it looks more authentic now.
I did get the wiring diagram for the screens and it looks like you could just wire a composite signal to them but you'd need to expirement, the head unit has to rear output if that is indeed the case... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #580424 19th Jan 2021 12:52pm
WellDrivenJames
United Kingdom 2004 Range Rover Vogue Td6 Adriatic Blue
verydisco wrote:
Is this one a simple Plug and play for early L322s (2002/2004) since it is for BMWs, please? or does one need adaptors?
Many thanks.
Would you mind sharing some pics?
cheers
Just to clarify with this, I've got a 2004 Vogue - If I fitted one of these with the 5m cable etc would I retain steering wheel controls?
Thanks
Post #583340 12th Feb 2021 10:39am
Danwilderspin
Yes that's correct
I've got this one and I recommend it seems to be working good after some initial teething issues.
They offer the 5 m cable when you buy.
https://www.erisin.com/products/erisin-es8...dvr-canbus Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583341 12th Feb 2021 10:44am
WellDrivenJames
Perfect, thank you!
It looks great and much nicer than a standard double din and facia. I want to keep the car as original and OEM as possible but I have limits when it comes to ICE. Laughing This looks like an easier solution than faffing about with Bluetooth kits with the existing HU that has dead pixels etc anyway.
Post #583344 12th Feb 2021 10:56am
Danwilderspin
Yes the only thing is it’s for an e53 x5 so it has a slight curve to it oem doesnt- this doesn’t not bother me but I can send a pic if needed.
It also has speaker outs if you want to bypass the dsp amp or you can run the RCA’s to the dsp amp get a resler interface (I might no a guy selling one ) get ibus app and bang you keep all the obc functionality too including equaliser on screen pdc.
I’d also install the office launcher it looks superb. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583367 12th Feb 2021 12:34pm
WellDrivenJames
Thanks!
I'm not in a huge rush, I only picked the car up yesterday, but it's still something on my list.
I'm currently using a bodged system via an Amazon Echo Auto connected via a tape adapter so sound quality is far from ideal - not to mention a the ugly cables... A nice all-in-one solution would do the trick. Failing that I've also had a look at a more simple solution of the GROM BT3 which simply replaces the CD changer with BT integration and even comes with the mic.
Post #583376 12th Feb 2021 1:01pm
Danwilderspin
Here is a pic:
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #583428 12th Feb 2021 4:56pm
MarkNL
Netherlands 2007 Range Rover Vogue SE TDV8 Java Black
Hi Dan
Just to be sure - by installing the latest Erisin (which looks wonderful !!) ... you have lost only the 4x4 info on display - and the output to the 2 headrest screens, correct ?
Back up camera, FM, DAB+, Dvd, bluetooth, steering wheel controls - all is OK ?
Or is there more functionality thats lost in the process ?
thanks Mark Offringa
Utrecht Netherlands
2007 L322 / 3.6 TDV8 / Vogue / Java black
2002 Mini Cooper / 1.6 116 hp / Red + white roof / the magic back-up Smile
Gone:
2002 L322 / 4.4 V8 / Vogue/ Adriatic blue
2000 Audi A6 / V8 4.2 / Brilliantschwarz
2003 L322 / TD6 HSE / Adriatic blue
Post #587233 12th Mar 2021 9:35pm
Danwilderspin
No dvd as that is not in the new head unit.
You also can’t set the clock but you can wire a button you press at midday when the clocks change to reset it.
I have just modified it again - and used and after market amplifier and ran cables to the back so if you need a 5m most cable and or the most to rca converter they may be available for sale soon!
You will also lose your audio fader front to rear as it only takes one channel unless you go the aftermarket route like i did!
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #587245 13th Mar 2021 12:30am
BVX
United States 2005 Range Rover HSE 4.4 V8 Zambezi Silver
Hi guys. Can someone give me a list of things to buy for an upgrade
Post #594666 19th May 2021 2:16am
Danwilderspin
Are you wanting to change the amp too? I personally would as it’s easier and sounds great on the stock speakers believe it or not Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #594679 19th May 2021 8:55am
WellDrivenJames
Danwilderspin wrote:
Yes that's correct
Just to bring this one up again (my apologies) - my DSP seems to be no more, does
It need to be working for sound to work with these units or do they bypass the need for the amp? '04 Adriatic Blue Td6 Vogue
Previous - '96 P38 DSE, '07 D3 HSE, '09 FL2 HSE, '00 FL1 (and many non-LR cars over the years!)
Post #596352 3rd Jun 2021 9:55pm
Danwilderspin
Good question- you can either join all the word together for each door from the amp plug and connect them to the headunit or run an external amp which is do so as not to overload the headunit.
If you are good with a soldering iron you will probably find the 12v plug has corroded off the pcb and needs some love Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #596368 3rd Jun 2021 11:29pm
Synfinite
Canada 2007 Range Rover HSE 4.4 V8 Stornoway Grey
Old thread but:
All links are dead now, do you have part #s? Please and thank you.
Post #663567 6th May 2023 2:07pm
Page 3 of 3 <123
