![]() | Home > My Range Rover > Back with another Supercharged |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1397 ![]() ![]() |
Top work, good thread |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16386 ![]() ![]() ![]() |
Why don’t you ask if anyone on here wants black wheels? Maybe cheaper to swap them than paint them? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3311 ![]() ![]() ![]() |
I did ask on the Facebook Group, didn’t think of asking on here actually.
Whilst moving the SC on the drive today I noticed that if it’s sat in gear at idle with your foot on the brake there is a slight lumpiness from the engine. If you move it into neutral or park it goes away.
I shouldn’t waste too much time or effort David, most that come in here do the exact same thing! Only when cold and always when sat in gear... Including wifeys 200k non SC LPG’d 👍 |
That’s interesting to know, thanks Craig. |
I must admit I put wifeys missing down to it running on LPG so when cold, may be injectors???
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Interesting Craig mine does this and tbf whilst i moan about the trims when I floor it as they are a little higher they are bang on at idle even when cold... did they do this from new I wonder? Current stable:
Thanks Craig.
What was wrong with th coupling out of curiosity?
I spun it when the belt was off and it felt pretty gritty and noisy so replaced it whilst the belt was off.
That antenna fault is standard equipment, David... I'd ignore it pal... |
