![]() | Home > Maintenance & Mods (L322) > GSM FBH Switch & Timer |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
So a little project to keep myself from climbing the walls. After getting my FBH back up and running I tested it by unpluging the 3 wire plug from the remote unit in the boot and then joining the +12v to the signal wire. The FBH and interior fans then start up and run until you disconnect the wires or I think it turns off on its own after 30 mins (did not test this theory however) what I did notice is within 10 minutes the interior was toasty so it does not need that long to do its job.
Bolert Member Since: 29 Jun 2021 Location: Hythe, Kent Posts: 35 ![]() ![]() ![]() |
Hey Chris,
Hi Bolert, THe meter needs to be put in line on the positive cable from the battery, you need a meter that can handle upto 10amps draw as when you connect it all up the RR will draw a high current initially as it sorts itself out, then leave for an hour and see what your draw is at this point. L322 2007 TDV8 3.6 |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1583 ![]() ![]() |
Neat, although I’m surprised GSM is still in use in the UK. It was turned off in Oz a few years ago and 3G will be going off shortly.
