![]() | Home > Technical (L322) > Rear brake pipes |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
Bit of a thread resurrection here but I’m trying to replace the rear O/S flexi brake pipe.
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
You undo it from the nut you see at the top of the pic where the old metal pipe is shown. It's years since I did mine but think that fitting goes inside the Flexi hose with a flared pipe end. Use a spanner in the flex so it doesn't twist. Current 2007 TDV8 Vogue Buckingham Blue |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
If you try to undo it with an open ended spanner you risk rounding it off...
Alternatively if you are replacing the metal brake pipe just cut it off and use a 6 point socket to prevent it rounding off. If you aren't replacing them then the a flare nut spanner is a good shout. Current 2007 TDV8 Vogue Buckingham Blue |
I had no plans to replace the metal pipe but it may well come to that. Got - 2017 SDV8 Autobiography in Loire Blue
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
I had to cut mine, there was no chance of it unscrewing.. best to cut it off as you dont want to break the bracket on the chasis it screws onto. Current:
