Home > Technical (L322) > Squealing sound |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I do not have a petrol i have a 4.4TDV8, from what i understand the job is a little easier as access is better on the petrol cars.
1st Mar 2021 10:15am |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 78 |
Thank you,
1st Mar 2021 1:06pm |
i get ya and no no know issues but the job is a pain to do so if you have it in bit why would you not change them all?
1st Mar 2021 2:02pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
I've just had the same issue with mine and I replaced the bearings in all of the pulleys.
1st Mar 2021 3:28pm |
Interesting. I will consider this route, the difference in cost is very big! What tools did you use to remove the fan? 2006 Supercharged |
2nd Mar 2021 5:53pm |
I bought a viscous fan tool from Powerful UK and used a long thin fan spanner to undo it. It took quite a lot of force. The most awkward bit was getting the fan shroud out past the air con pipe.
3rd Mar 2021 10:05pm |
Thank you for that info! I changed a water hose from the pump to the back of the engine without removing the shroud, very avkward. I remember concluding that it was impossible to remove the shroud without removing the AC pipe, I see I was wrong. 2006 Supercharged |
3rd Mar 2021 10:42pm |
I broke my original shroud when I removed it and have just replaced it.
3rd Mar 2021 10:57pm |
I read somewhere that the shroud could be split, is this not the case, and you need to remove the fan and shroud at the same time? What are the engineers thinking🙄 2006 Supercharged |
4th Mar 2021 7:12am |
I had a look through old posts to see if there was some history missing and this post just stopped so I will update now for others that search.
22nd May 2023 12:28pm |
