Home > Technical (L322) > Dash Info Menu
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Dash Info Menu
A quick question, does anyone know why the "service" option on the dash menu is blanked, i.e. Won't let me click on it? What options should I see? Late 2009 3.6TDV8. Thanks
 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #588637 24th Mar 2021 12:26am
It's because the engine is running, it tells you the oil level but you have to leave it for 20 mins after you have switched off for it to work. Switch just the ignition on to read it. It also shows the VIN IIRC.... Pete
Post #588642 24th Mar 2021 1:04am
Ricardo Villa
Never tried that! Thanks for tip will check it out later. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #588694 24th Mar 2021 11:33am
DrRob
Owners Manual also has instructions for oil level reading Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588699 24th Mar 2021 12:32pm
bishbosh10
You don't have to wait 20 mins -
Ignition on, bonnet open.
Go to oil level through the menus.
When it says "oil level not available" double click the Cancel Cruise Control button and the oil level will be displayed.
Note that it is very sensitive to gradients so make sure the car is on a level surface and also note that to get a good reading you should wait a bit to let the oil drain back into the sump. Thumbs Up Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #588716 24th Mar 2021 2:50pm
DaleL322
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I thought the oil level menu was only available on the 4.4? 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
https://www.fullfatrr.com/forum/topic58777.html
Post #588721 24th Mar 2021 4:06pm
There is no dipstick on the 5.0 engine... this is the only way to check it's level... Thumbs Up Pete
Post #588790 24th Mar 2021 9:46pm
mjdronfield
The oil level option won’t be there on the 3.6, but other options should be. As mentioned already, try it with the engine off. Might get to choose the menu then?
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #588794 24th Mar 2021 10:06pm
Ricardo Villa
Thanks for replies, didn't get out today, will have a look tomorrow. It must tell me something!! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #588811 25th Mar 2021 12:16am
Ricardo Villa
Well finally got to check, indeed the Service option does light up if engine off, disappointed only option is to view the cars Vin number☹️ At least it does work I suppose. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #589508 29th Mar 2021 11:49pm
mjdronfield
Mine doesn’t have much else....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #589875 1st Apr 2021 3:46pm
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
That's all I get on mine, too.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #589927 1st Apr 2021 11:32pm
Ricardo Villa
Yes I only get the VIN bit, guess it's dependant on Year, mines a 3.6 as well. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #589929 1st Apr 2021 11:42pm
mjdronfield
3.6 has proper dipstick.
My 4.4 only has a dipstick in the driving seat.
....come on... that’s funny.... I’ve only just woke up 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #589950 2nd Apr 2021 9:22am
Laughing ... - .- -.
Post #589963 2nd Apr 2021 10:33am
