![]() | Home > Technical (L322) > Dash Info Menu |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8600 ![]() ![]() ![]() |
It's because the engine is running, it tells you the oil level but you have to leave it for 20 mins after you have switched off for it to work. Switch just the ignition on to read it. It also shows the VIN IIRC.... Pete
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Never tried that! Thanks for tip will check it out later. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4337 ![]() ![]() ![]() |
Owners Manual also has instructions for oil level reading |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
You don't have to wait 20 mins -
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 ![]() ![]() ![]() |
I thought the oil level menu was only available on the 4.4? 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
There is no dipstick on the 5.0 engine... this is the only way to check it's level... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7923 ![]() ![]() ![]() |
The oil level option won’t be there on the 3.6, but other options should be. As mentioned already, try it with the engine off. Might get to choose the menu then?
Thanks for replies, didn't get out today, will have a look tomorrow. It must tell me something!! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Well finally got to check, indeed the Service option does light up if engine off, disappointed only option is to view the cars Vin number☹️ At least it does work I suppose. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Mine doesn’t have much else....
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
That's all I get on mine, too.
Yes I only get the VIN bit, guess it's dependant on Year, mines a 3.6 as well. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
3.6 has proper dipstick.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35685 ![]() ![]() |
