Home > Technical (L322) > heated steering wheel: will a later type fit the 2005 Model?
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Hi, my heated steering wheel stopped heating Twisted Evil
My FFRR is a 2005 MY. Does anyone know if a steering wheel from a later type L322 will fit mine?
Thanks! Thumbs Up
Post #591021 12th Apr 2021 8:04pm
Merchy
Not quite 100% positive, but when looking for bits for my steering wheel, it looked like the same wheel will fit cars from 2002 to around 2010 / 2011.
Powerful uk have a video about removing the steering wheel and quote the same wheel 2002 to 2011
Maybe some very high spec wheels may have additional functions / different wheel.
E-bay seem to have the lot, in different specs / trim, leather colours etc.
Hope this helps.
Post #591026 12th Apr 2021 8:48pm
Rangie4fun
Thanks Merchy! Will check PowerfullUK Bow down
Post #591027 12th Apr 2021 9:13pm
mjdronfield
The wheel you tend to buy is just the leather rim with spokes and the hub. It’s bare, so you transfer your wiring pretty much. I put a later wheel on to my 2003 car when I had it, and had to keep the original module so the connector fitted. I think it had a bit of wiring with it, thinking on.
So yes, it will fit, but you might need to mix and match if your new one has any wiring.
Here’s the thread I did at the time....
https://www.fullfatrr.com/forum/topic13068...ring+wheel
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #591029 12th Apr 2021 9:43pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Just make sure it's actually the steering wheel heating element that's at fault before you replace it. Mine wasn't working and I recently fixed it by replacing the relay which provides power to it.
Post #591032 12th Apr 2021 10:24pm
Steering wheels from 02-13 are all the same fitment sir... Thumbs Up
Post #591035 12th Apr 2021 11:30pm
Rangie4fun
Hi all! Thanks for your help! Been in the car today en checked the heating element: when straight connected to an external battery no heat at all. Double checked with an ammeter: no resistance whatsoever. Beside that the heating element (when sort of working long ago...) heated over on some spots and did barely nothing on others. So it was on the way out then I guess Sad
Now finding a nice wheel with a perfect heating element isn't easy. I saw some on ebay, but hard to tell if they are okay or on the way out... Someone with an idea?? Bow down
Post #591109 13th Apr 2021 5:22pm
kezbo1981
You can check the resistance of the heating element with a multimeter, powerful UK have a video on YouTube on how to.
I've got a spare steering wheel in the garage I've been meaning to check over and then sell on.
Post #591113 13th Apr 2021 5:44pm
Rangie4fun
Hello Kezbo, very informing video! Didn't check the thermister but did check the resistance on the heating element and that was definitely dead Big Cry So a new steering wheel is due. When your spare is okay and willing to sell, than please PM me.
Post #591130 13th Apr 2021 8:42pm
