Home > Technical (L322) > 4.4 TDV8 Head Gasket Failure
mattgage
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
Hi Rob,
I'm afraid I went a bit OTT and bought the entire pipe units for both leaks, but just replaced the top pipe O rings as the leaks were at the top of the engine and I didn't want to have to go deeper to disconnect the bottom ones.
The leaky O ring to the oil cooler I think also is on the pipe that also cools the EGR. Part number LR022718. I just bought the part then took its O ring out so I didn't have to disconnect the existing one.
This is the offending pipe, and the O ring inside was completely perished, so disconnecting it to do the oil cooler must have finally screwed it. I tried to find the O ring size and type but wasn't sure what it was made of and its exact size. £25 for the whole pipe assembly:
The other O ring is on the small pipe coming off part number LR029140. Be careful as the smaller cross pipes that connect to the main pipe have a fragile connection that can snap. The leaky O ring was coming from the small pipe with the clip on - and NOT the one with the yellow bit attached. It's down to the slight right of the V under the manifold (as you look at the engine).
I did search quite hard for a LR specific coolant pressure tester but no joy - or v expensive. The set I bought (an eBay gamble) has the right fitting for the TDV8 expansion tank and worked very well. £50. I think a handy tool for testing cars we are thinking of buying as coolant leaks are often ignored, sometime tough to locate, and can lead to big problems longer term. Good luck and keep us posted - there are more O rings in my 2012's system to perish yet!
Post #591314 15th Apr 2021 3:09pm
DrRob
Thanks!
I've sent in a cheeky offer
https://www.ebay.co.uk/itm/PRO-Radiator-Co...23a5a44ec1
EGR pipe for reference Thumbs Up
https://www.island-4x4.co.uk/hose-genuine-lr022718-p-38391.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #591323 15th Apr 2021 4:05pm
DrRob
Matt
Do you lose a lot of coolant replacing the EGR O ring?
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591350 15th Apr 2021 7:43pm
mattgage
Hi Rob. No didn’t lose much. I did it when I changed the oil cooler (I replaced the whole unit) and, on triumphant and lovingly cleaned assembly of the new oil cooler and decoked manifold, I then spotted coolant leaking below. I soon spotted the leak so had to remove all the gubbins again to get to it. I don’t know if it was leaking before but disconnecting and reconnecting it obviously loosened up the seal and I found the O ring looking rotten so replaced. No big gush of coolant when disconnecting from memory as near the top of the engine. Good luck!
Post #591369 15th Apr 2021 10:54pm
4040
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Could someone explain what and where the EGR cooler is please. I can’t find and reference to it in the manual. Thanks
Post #591374 15th Apr 2021 11:55pm
GGDR
sits on top of the 'V' (rear) under the intake that we tend to call the 'donut'.
Number 10 on the drawing
. Cheers, Greg
Post #591378 16th Apr 2021 6:43am
GraemeS
Australia
10 & 11 is the EGR valve, with 10 probably the actuator. The cooler comprises of 13 and 15, with 13 located inside 15. 2 is the oil filter and cooler which sits atop the EGR cooler.
Post #591395 16th Apr 2021 10:31am
4040
Thanks, I did the oil cooler gaskets myself, but didn’t really realise what was under it. More potential trouble by the looks Sad
Post #591488 16th Apr 2021 11:43pm
DrRob
Rodjules wrote:
Thank you all for your advice and comments. Confirming my thoughts that I hadn’t seen anything on the forum regarding HG on the 4.4. I went into the MD and spoke to the senior technician who is now on the car and pointed him towards the oil cooler gaskets. Will wait and see what they report back but think I will get a second opinion before authorising HG replacement. To be fair I have used this MD for many years and they have always been very good. Will keep you all in the loop on how I get on Thumbs Up
Did changing those 2 pipes sort your small coolant loss? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #620536 19th Jan 2022 9:07am
Rodjules
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Yep had them both changed as O rings were perished when checked and all appears well, although to be fair have done very limited mileage since. (Combination of COVID & working overseas). 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
2012 L322 Range Rover 4.4 Westminster Baltic Blue, Ivory - Deceased
2012 Discovery 4 HSE 3.0 Sdv6 Oslo Grey, Black - Gone
2006 L322 Range Rover Td6 Vogue SE Buckingham Blue, Parchment - Gone
1996 P38 Range Rover 4.6 HSE Rioja Red, Black - Gone
1990 Landrover 110 2.5TD CSW - Why Oh Why ???
Post #620738 20th Jan 2022 11:39pm
DrRob
Mine turned out to be a small leak from the EGR cooler which sits below the Oil Cooler in the V.
A small amount of red crystalline residue was seen sitting on the block in the V once the inlet "donut" was removed.
All stripped out, inspected, cleaned and new EGR gaskets fitted. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623668 14th Feb 2022 1:34pm
JayGee
I'm loosing a small amount of coolant and will have to get this checked out. Not sure if it' easier to just keep topping it up...... 2012 TDV8 Vogue (L322)
Post #623669 14th Feb 2022 1:46pm
DrRob
Pics to follow..... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623694 14th Feb 2022 7:10pm
DrRob
Red stuff visible
Strip down
EGR strip and clean
Post #623695 14th Feb 2022 7:11pm
