![]() | Home > Technical (L322) > 4.4 TDV8 Head Gasket Failure |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Thanks!
Matt
mattgage Member Since: 21 Apr 2014 Location: Suffolk Posts: 38 ![]() ![]() ![]() |
Hi Rob. No didn’t lose much. I did it when I changed the oil cooler (I replaced the whole unit) and, on triumphant and lovingly cleaned assembly of the new oil cooler and decoked manifold, I then spotted coolant leaking below. I soon spotted the leak so had to remove all the gubbins again to get to it. I don’t know if it was leaking before but disconnecting and reconnecting it obviously loosened up the seal and I found the O ring looking rotten so replaced. No big gush of coolant when disconnecting from memory as near the top of the engine. Good luck! |
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 ![]() ![]() ![]() |
Could someone explain what and where the EGR cooler is please. I can’t find and reference to it in the manual. Thanks |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
sits on top of the 'V' (rear) under the intake that we tend to call the 'donut'.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
10 & 11 is the EGR valve, with 10 probably the actuator. The cooler comprises of 13 and 15, with 13 located inside 15. 2 is the oil filter and cooler which sits atop the EGR cooler. |
Thanks, I did the oil cooler gaskets myself, but didn’t really realise what was under it. More potential trouble by the looks |
Did changing those 2 pipes sort your small coolant loss? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
Rodjules Member Since: 03 Mar 2016 Location: Bishops Stortford Posts: 68 ![]() ![]() ![]() |
Yep had them both changed as O rings were perished when checked and all appears well, although to be fair have done very limited mileage since. (Combination of COVID & working overseas). 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
Mine turned out to be a small leak from the EGR cooler which sits below the Oil Cooler in the V.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3380 ![]() ![]() ![]() |
I'm loosing a small amount of coolant and will have to get this checked out. Not sure if it' easier to just keep topping it up...... 2012 TDV8 Vogue (L322) |
Pics to follow..... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Red stuff visible
