![]() | Home > Technical (L322) > new air compressor |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Good for plug n play mate unless you want the height adjusted |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Great, thought as much.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2264 ![]() ![]() ![]() |
Good for plug and play if you are swapping like for like Current stable:
Put new compressor in as well as relay, still sitting on the bump stops. |
Hi guys n gals,
what's the fault? you could have a block or split line? Current stable:
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Before you start pulling any other bits off, run the car stationary, reset steering angle lock to lock and go round the block , not italian style. Then try to set car to all three heights, keep going up and down numerous times
I got physio at 0900 tomorrow so I,ll leave it till after that.
