Home > Technical (L322) > new air compressor
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
new air compressor
Hi all,
Am getting a new air compressor and was wondering if it needs to be coded into the system,
or is it plug and play.
Will be getting a new relay as well.
Beast is an old TD6.
TIA
littlecub
Post #591974 21st Apr 2021 10:36am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Good for plug n play mate unless you want the height adjusted
Post #591981 21st Apr 2021 11:36am
littlecub
Great, thought as much.
AS long as it pumps it up from the bump stops, as thats where its sitting at
the moment. Rolling Eyes Laughing
Post #592032 21st Apr 2021 9:06pm
Danwilderspin
Good for plug and play if you are swapping like for like Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592176 22nd Apr 2021 10:48pm
littlecub
Put new compressor in as well as relay, still sitting on the bump stops. Censored
What do I need to do to get it to work.
Tried my iid tool,did nothing.
Getting really Censored off with this.
Post #592497 27th Apr 2021 4:18am
littlecub
Post #592498 27th Apr 2021 4:19am
littlecub
Post #592499 27th Apr 2021 4:20am
littlecub
Hi guys n gals,
a) Sorry for the triple post, twas a mite peeved off and computer kept going back to my post instead of
going to the first page of the saga.
b) Went for a quick spin around the block as I read somewhere that that will reset suspension and yes it did.
Bow down Bow down Thumbs Up
Havent tried putting into access or raised yet, but the front seems to be a bit higher up than previously looking at it.
Measuring from centre of wheel to the body I get 510mm. Thats the front.
Didnt try the back as that looks OK.
Also the pump was still working when I turned it off as it had been running for a good 10 mins.
Is there anything else I need to do or is that it.
TIA
littlecub
Post #592500 27th Apr 2021 5:29am
Danwilderspin
what's the fault? you could have a block or split line? Current stable:
2015 5.0 V8 S/C AB
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #592512 27th Apr 2021 9:28am
Merchy
Before you start pulling any other bits off, run the car stationary, reset steering angle lock to lock and go round the block , not italian style. Then try to set car to all three heights, keep going up and down numerous times
After mine had been up in the air once, the fore and aft heights were different, operating the system a good few times sorted it out - may have just been lucky, but try this first, then you will have the full picture, so to speak.
Post #592513 27th Apr 2021 9:58am
littlecub
I got physio at 0900 tomorrow so I,ll leave it till after that.
I,ve also got a 15 min hwy run, so I,ll see if it goes into hwy mode as well.
There,s a few places that I,ll be stopping at tomorrow so I,ll play around with it as well.
Thanks for the tips as well. Thumbs Up
littlecub
Post #592516 27th Apr 2021 10:21am
