![]() | Home > Technical (L322) > Roof Rail Trim Caps |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
I am assuming that the rail is inserted into the gutter as on a 2006, if that is the case, I imagine that a main stealer would only supply a whole rail ( Probably a pair ) expensive. If no one has a spare try several breakers, you would probably have to buy the rail insert? but it should be quite cheap, especially as there will not be a big demand for these. You might get lucky and just get the insert that way. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8618 ![]() ![]() ![]() |
Somebody was 3d printing these and selling them on eBay, can't see them now though... the complete rails are very expensive to replace, there are some second hand ones on eBay but they want £150 for them |
https://www.ebay.co.uk/itm/324441498772?ha...Sw~O9f80em
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 258 ![]() ![]() ![]() |
Thanks for the replies. Ordered from eBay, and in the correct colour which is a bonus! |
Excellent find...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
They are quite difficult to get in without breaking them IiRC Pete. Not even sure they can be fitted from the top, pretty sure that the rails have to come off so that you aren’t forcing them in. There is nothing that can't be fixed with a hammer😜😜
Had a good look at mine this morning, ( Standing on a small ladder, in the rain - as you do ) |
They do come out, a monkey removed one of mine in Longleat.....
nmj - I now have this mental image in my head of a monkey waving a roof rail insert at you, whilst you go completely mascara, ( Go apeshit would be too bad a pun ) whilst trying not to swear in front of the Missus and kids |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 ![]() ![]() ![]() |
Yes, they can be removed, and I assume installed, from the bottom side of the rail.
RR2B,
And there was I thinking it would be a simple 5 minute job! Thanks for all the tips and info. |
Now you’ve got me worried! Surely the watertight integrity of the roof doesn’t rely on a grub screw being in place? |
Don't worry, the threaded hole is blanked, not straight through, so don't worry about water ingress.
