Home > Technical (L322) > Roof Rail Trim Caps
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Roof Rail Trim Caps
Just discovered one of the roof rail trim caps is missing. Are these readily available? Searched the usual suspects to no avail (unless I'm using the wrong terminology). Thanks in advance.
Post #592967 2nd May 2021 5:53pm
Merchy
I am assuming that the rail is inserted into the gutter as on a 2006, if that is the case, I imagine that a main stealer would only supply a whole rail ( Probably a pair ) expensive. If no one has a spare try several breakers, you would probably have to buy the rail insert? but it should be quite cheap, especially as there will not be a big demand for these. You might get lucky and just get the insert that way.
Post #592987 2nd May 2021 9:29pm
Somebody was 3d printing these and selling them on eBay, can't see them now though... the complete rails are very expensive to replace, there are some second hand ones on eBay but they want £150 for them Shocked Pete
-Click here for Thread-
Post #593005 2nd May 2021 10:45pm
Merchy
https://www.ebay.co.uk/itm/324441498772?ha...Sw~O9f80em
Think I have found what you want on the above E-bay link, in Blue for £10 including postage. Some others have posted for same parts at £20, still better than expected, I hope. Thumbs Up
Could be a bit fiddly to do, but cheap Very Happy
Post #593007 2nd May 2021 11:35pm
RR2B
Thanks for the replies. Ordered from eBay, and in the correct colour which is a bonus!
Post #593025 3rd May 2021 8:35am
Excellent find...
Can you post on here how hard they are to replace, I have some to do... Thumbs Up Pete
Post #593028 3rd May 2021 9:04am
They are quite difficult to get in without breaking them IiRC Pete. Not even sure they can be fitted from the top, pretty sure that the rails have to come off so that you aren’t forcing them in. There is nothing that can't be fixed with a hammer😜😜
Post #593033 3rd May 2021 10:03am
Merchy
Had a good look at mine this morning, ( Standing on a small ladder, in the rain - as you do ) Rolling with laughter
I think that the whole rail has to be taken out of the gutter. A decent trim tool kit would make this easier. I hope!!!
Post #593035 3rd May 2021 10:51am
They do come out, a monkey removed one of mine in Longleat.....
Need to be very careful with them as they are quite flimsy. There is nothing that can't be fixed with a hammer😜😜
Post #593036 3rd May 2021 11:08am
Merchy
nmj - I now have this mental image in my head of a monkey waving a roof rail insert at you, whilst you go completely mascara, ( Go apeshit would be too bad a pun ) whilst trying not to swear in front of the Missus and kids Rolling with laughter Rolling with laughter Rolling with laughter
Mind you, it appears that those monkeys in Longleat have more skills than some car mechanics I have met over the years. Whistle
Post #593040 3rd May 2021 11:48am
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Yes, they can be removed, and I assume installed, from the bottom side of the rail.
The issue is that the official instructions for installing the roof rack say to flip up this piece and then cut them out! If you follow these instructions they can never be reused.
https://www.fullfatrr.com/gallery/albums/u...iagram.jpg
I used a plastic trim tool to carefully pull up those rails and found that yes, they can be carefully removed.
You may end up breaking some of the clips that hold the rail down to the roof. There are two different types of clips that hold the rail down:
(1) White Clip: LR014488
(4) Black Clips: DBE000011
These are available through either your Land Rover dealer or on eBay.
Good luck everyone!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #593054 3rd May 2021 3:20pm
lschwarcz
RR2B,
I also noticed that the screw hole is empty! There is supposed to be a screw in there when you don't have a roof rack installed. I'm assuming this is to keep the threads clean and possibly to prevent water from leaking into the car (I don't know this is correct).
I haven't been able to find the official Land Rover part number for this screw but you can buy them online.
If you want to replace this you want an 18-8 Stainless Steel Cone-Point Set Screw, M8 x 1.25 mm Thread, 20 mm Long.
If you can't find any over there this place in the USA has them:
https://www.mcmaster.com/91217A320/
Good luck!
Bournville/Ivory
Post #593055 3rd May 2021 3:29pm
RR2B
And there was I thinking it would be a simple 5 minute job! Thanks for all the tips and info.
Post #593058 3rd May 2021 4:24pm
RR2B
lschwarcz wrote:
RR2B,
Good luck!
Larry.
Now you’ve got me worried! Surely the watertight integrity of the roof doesn’t rely on a grub screw being in place?
Post #593062 3rd May 2021 4:54pm
Merchy
Don't worry, the threaded hole is blanked, not straight through, so don't worry about water ingress.
The bits mentioned are simple 'stainless steel grub screws' to keep dirt out of the threads to keep them clean, as cleaning out dirt / rust filled threads would be a pain, and could entail the use of a thread tap.
https://www.westfieldfasteners.co.uk/Bolts...nless.html
Above is a link, these are available from ANY engineering supply merchants, nothing special about them.
Grub screw, cup point, allen head, stainless steel, M8 thread ( Coarse not fine ) length 20mm, just fit with a dab of grease. Thumbs Up
Post #593066 3rd May 2021 5:33pm
