Home > My Range Rover > New to me 2011.5 AB
Page 3 of 4 <1234>
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
The RR Bandit wrote:
This isn't by any chance your RR is it? I saw this and recalled seeing yours on here then read the comments and saw he is also in Aus.
https://www.reddit.com/r/AutoDetailing/com...er_that_i/
Wow what a thread. A great reminder to stay away from Reddit, people can't read and have no appreciation/understanding of how things are in other countries...I find that Facebook groups attract similar kind of dumb audiences...
There is one drawback with less common interior colours, and that is finding parts on Ebay and the likes. Heck even with a black interior I found it hard finding a parcel shelf for reclining rear seats.
Post #592391 26th Apr 2021 6:06am
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
No further issues with starting
Also:
Secured a seat base cover from USA for 150USD + ship
Going in for check up today
Apple Car play booked in next week
Detail work TBD SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #592487 26th Apr 2021 10:27pm
ffrr14
update
Car back from inde, one intake hose clamp loose otherwise all ok
Proactively replaced:
Alternator
Starter
Belt, water pump, pully, tensioner etc checked , one belt replaces
Rear brake replaced (front renewed by previous owner)
A service
Underside of car very clean. Appears front struts replaced with bilsteins at some stage, but rear looks original.
Todo:
Apple carplay next week
Paint correction still thinking how to tackle this
Proactive Service of compressor
Second set of wheels with AT, not sure 20" or 19" any recommendation?
Otherwise leather clean this weekend SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #592825 30th Apr 2021 9:19pm
ffrr14
apparently it is not the end of the story..
Today I experienced non start condition again, car was parked up at the mechanic for a few days prior, do i have a parasitic drain? what could it be now?
used a noco to start without issues and since then have it on a CTEK MXS15c charger and seems ok
...Ideas?
Note: The new battery state of charge was not known prior SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #592847 1st May 2021 7:56am
ffrr14
Carplay added
Engine tune added
EGR Closed
Wah what a difference!!
275 kw
368 hp
810 nm
Drain persists @1.8A!! Surprised SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #593110 4th May 2021 12:27pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Just a thought with the drain has it got a tracker fitted? I have read about quite a few issues with old trackers never being removed. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #593197 5th May 2021 2:23am
ffrr14
what is a tracker? how do I find if one is fitted?
Thanks for the thought SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #593198 5th May 2021 3:02am
wayneg
GPS tracker in case of theft. generally well hidden from view and unmarked. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #593199 5th May 2021 6:16am
ffrr14
ok, have to do a bit of digging then SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #593200 5th May 2021 6:31am
wayneg
It might be worth asking if anyone else has found one and where it was, you might get an answer via private message 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #593202 5th May 2021 8:09am
GraemeS
Australia
ffrr14 wrote:
Engine tune added
EGR Closed
275 kw
368 hp
810 nm
Where did you have it done pls?
Post #593209 5th May 2021 8:52am
The gearbox is only rated at 750Nm IIRC so be careful with Grand Prix starts..!! Thumbs Up Pete
-Click here for Thread-
Post #593245 5th May 2021 12:29pm
ffrr14
so already on limit from factory? Wont be going anywhere quick and no towing either SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #593261 5th May 2021 1:50pm
ffrr14
I am told the torque limit programmed into the TCM is 850Nm. ZF rates the torque capabilities of the 8HP70 @1000 max.
https://www.zf.com/products/en/cars/products_29289.html
So should be ok! SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #593654 8th May 2021 10:45pm
ffrr14
update
Car is all sorted now, thanks for all your help along the way.
Things I have done:
Replaced
- Starter
- Alternator
- Battery
- Starter switch
- 4 x HVAC stepper motors
- Drivers Set Base cover
- air compressor desiccant
- Relays (40 and 70 amp)
- Rear Shocks
Addded:
- Second battery (yellowtop + traxide)
- Carplay
- Interior bulb replacement with LED
- FBH remote/receiver
- Rubber mat
- Falken wildpeak on 10 spoke wheels
Resolved: (edited)
Looks like Charging issue can be cause by various things:
- Interference
- Short
- Loose terminal
- Poor Earth
- Battery programming
Have cleaned all the major electrical contacts etc and the car is much happier.
pd SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New : G350D
Post #599233 30th Jun 2021 10:16am
Page 3 of 4 <1234>
