Home > Maintenance & Mods (L405) > Wiper Blades |
3rd May 2021 2:56pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7724 |
Be careful, they changed design on the L405, not quite sure when - https://www.fullfatrr.com/forum/topic32300.html |
3rd May 2021 3:15pm |
The website asks for your reg. number.
3rd May 2021 4:37pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
went OEM...one place OEM is the best IMO 2014 FF Autobiography 5.0 SC
4th May 2021 3:34pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16146 |
I think they changed in about 2017? |
4th May 2021 7:10pm |
Ocean53 Member Since: 14 Feb 2018 Location: Chichester Posts: 71 |
I have now managed to change front wipers, ( instructions on how to park in winter position on the control system)
7th May 2021 3:40pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1141 |
I may be talking old school here, as my RR is old, operate rear windscreen wiper and just before it teaches mid stroke, switch off engine / car completely without touching windscreen wiper control, so wiper arm is now at 6-O-clock, worth a try. |
7th May 2021 4:11pm |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 711 |
Put them in the wiper change position and the front ones come up much further than they do in winter park and the rear moves down into a vertical position at the same time. I can’t remember the exact process, but it is in the manual. Something like turn ignition on, then off, then push down on the wiper stalk. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
7th May 2021 4:21pm |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 54 |
Follow this sequence with door open or closed.
7th May 2021 4:29pm |
That’s what I couldn’t quite remember! Works on my 2019MY MY23 Panamera E-Hybrid
7th May 2021 4:36pm |
👍 will give it a try tomorrow |
7th May 2021 5:04pm |
Plan B for the rear - it stops mid stroke if you open the tailgate. Can be a bit tricky as if you press the button again too soon, it closes again, but too late and it's too high..... |
7th May 2021 5:11pm |
QWERTY worked a treat, thanks |
8th May 2021 11:07am |
8th May 2021 2:18pm |
