![]() | Home > Maintenance & Mods (L322) > M62 v8 timing chain and guides replacement |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1048 ![]() ![]() |
Yep both should have a internal spring the new ones do for sure. I'm glad my guy knows his stuff. |
We broke x2 so far and a drop down tool. |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 831 ![]() ![]() ![]() |
how are you going RR 2005 4.4 petrol
So we dont cause any engine damage iv got another cam shaft comming. Gonna spin off and replace the gear wheel on that and just swop the cams over then it's just the final assembly |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 343 ![]() ![]() ![]() |
Are you trying to get the vanos units off the cam? |
what you mean "spin off" RR 2005 4.4 petrol
No not trying to remove the vanos units just trying to get the timing gear off the exhaust cam the bolts is well and truly on and wont shift. |
I suspect that this is your problem:
This may also help................
Yep we did that or at least my mechanic did that he has rebuilt a fair few of these engines and and done plenty of timing chains and guides. He always uses a 27mm spanner on the cams as he doesn't fully trust the cam locking tool. It's just that this cam sprocket bolt just wont shift........ he is pretty sure it being the 1st one on the engine it takes all the torque and over time just tightens its self up. He was holding the cam with x2 spanners while I used the rattle gun it puts out over 450 foot lbs or torque and still wouldnt shift...yes we know its left handed thread. ![]() |
It’ll fall out now then |
Spare exhaust cam shaft arrived today so this is going back together tomorrow.
as you are replacing the camshaft, i would be checking the camshaft followers and making sure that they collapse
Well we didnt need to replace the cam shaft after all. After removing it from the car and with proper force and larger breaker bar applied the cam gear bolt cam out. Happy days. It's all going back together very nicely.
