Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel.
TJH1985
Had a good poke around and there is very little movement in it, all the others are there so I’m confident it will be ok. The old bracket wasn’t doing much either given it’s condition.
If it came with one I’m not sure why they would have removed it, maybe LR have revised the design to prevent the issue Question Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #593642 8th May 2021 7:59pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Was the clip that was removed to hold the pipe from moving or was just a clip to hold the plastic sheave ?
Could they have not fitted a marine stainless clip ? So no more corrosion .
At least they found it.Or you found it, and problem solved.
Post #593663 9th May 2021 1:52am
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi
I have a 2014 L405 with the exact same water leak. There are coolant pipes that run from the front to the rear.
I took mine to my local garage not the main dealer and after £2100 it was fixed. Big Cry
The parts LR096502 & LR085582 are relativity cheap £104 & £160. It was the £1440 labour that was the issue. The rear back end of the car had to be lowered for access. Shocked
It took four days but all back on the road again. The car as I mentioned was a 2014 with 97K miles.
Oh the joys of motoring Bow down
Autobiography 3.0 14M5
Post #594848 20th May 2021 9:08pm
My point of the thread was to warn owners about the expense and difficulties in removing the rear cradle to replace these rear pipes! Mine happened @ 4yrs old and wasn’t covered under the JLR used car warranty scheme!
I think you were very lucky the bolts came out of the body! Many don’t! And when they don’t, they take the body mount threads with them! Steel bolt into an Aluminium body!
Just so all who read this later understand the risks in trying! 👍
Post #594861 21st May 2021 9:00am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I've done one of these, and if you do it the right way the job is not as hard as some might think.
The leak comes from corrosion in the pipes where the sleeve covers it:
Easiest way to fix seems to be to drop the fuel tank - which is not that hard of a job if you have a lift - rear prop off, exhaust off, some guarding off, then you have access to the tank. Drop the tank a bit and you have access to the connectors on the top:
You then have easy access to the pipes:
We just removed the old rubber hose, cut the aluminium pipe and used a longer piece of rubber hose over both aluminium pipe ends secured with jubilee clips - though there is a restrictor in the old pipe that needs to be moved over. Whole job took an afternoon and would get much quicker a second time. Current:
- 2013 L405 4.4 TDV8 Vogue
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #594864 21st May 2021 9:03am
TJH1985
They covered ours @5+ Years old without hesitation, How could they not cover a coolant leak?! Corrosion or something? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #594867 21st May 2021 9:22am
Don't shoot the messenger sir... I know not why they would not cover this? or indeed if i was being fed the correct information! Cheltenham Heritage MD were the dealership that told me i should ready myself for the bill if & when warrenty rejected it! They could have been feeding me a croc of Censored for all i know!
For me it was easy to remidy, so i did... The thread is to warn future owners etc etc etc sir Thumbs Up
Post #594876 21st May 2021 9:53am
Aspentree
United Kingdom 2014 Range Rover Autobiography SDV8 Corris Grey
Is it possible to see these pipes by removing the rear wheel and the plastic liners or do you need to remove the exhaust and fuel tank?
Post #615233 7th Dec 2021 9:51pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Re: L405 Coolant Leak From In Front Of The Rear Wheel.
A quick heads up for all the 405 owners out there. I have found a water leak on my 2013/14 L405 AB and unusually its from in front of the UK drivers side REAR wheel! Im guessing they run to rear passengers heating? Maybe?
The black metal thing in these pics is the fuel tank protector.
Removing the very rusty metal securing tab/bracket, then the rubber coating i found it was leaking from a pinhole size hole/maybe a crack, maybe from the rusty bracket? 10mm away from the end where the rubber pipe/hose connects... JLR MD wanted nearly a grand to remove the rear subframe/cradle and replace (just that 18" aluminium pipe) Shocked Sniggering Thud
So, i simply replaced the rubber pipe/hose (on the right in the pics) with a piece 30mm longer and cut the ali pipe back 20mm so beyond the crack/pinhole and fitted the new/longer rubber pipe/hose... Happy days, no more leak!
For someone with no technical mind whatsoever ...
Where do you look to see this? And do you need to remove anything?
I've started getting the "low coolant" warning and this seems an obvious place to look.
That said, the car had it's oil cooler replaced before I bought it, so it could be leaking round there. What do I put here then?
Post #619128 7th Jan 2022 5:36pm
I would start by topping up the coolant with the correct type, then monitor and fill for a week or so of normal driving. It’s possible that when the cooler was changed the system wasn’t bled properly and you are seeing the system bleed itself….. failing that start looking for the rear coolant pipe…..
To see it properly IIR you have to get under the car and look to the drivers side of the fuel tank. It’s between the tank and the body shell. There is nothing that can't be fixed with a hammer😜😜
Post #619185 8th Jan 2022 12:42pm
GAC23
Thanks for the tip.
Will top up this morning and see.
It’s off to the local Indy for something else on Tuesday. Have asked them to have an informed look too. What do I put here then?
Post #619188 8th Jan 2022 12:57pm
GAC23
All sorted by the lovely people at Langley 4x4
Hose on the radiator was the problem. What do I put here then?
Post #619802 13th Jan 2022 12:36pm
