![]() | Home > Maintenance & Mods (L405) > L405 Coolant Leak From In Front Of The Rear Wheel. |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
Was the clip that was removed to hold the pipe from moving or was just a clip to hold the plastic sheave ?
Mariana Black Member Since: 30 Jul 2014 Location: Stockton-on-Tees Posts: 89 ![]() ![]() ![]() |
Hi
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16366 ![]() ![]() ![]() |
My point of the thread was to warn owners about the expense and difficulties in removing the rear cradle to replace these rear pipes! Mine happened @ 4yrs old and wasn’t covered under the JLR used car warranty scheme!
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 400 ![]() ![]() ![]() |
I've done one of these, and if you do it the right way the job is not as hard as some might think.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
They covered ours @5+ Years old without hesitation, How could they not cover a coolant leak?! Corrosion or something? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8 Previously George a 2007 MY07 Java Black VSE 3.6 TDV8 Previously a 04 MY04 Defender 90 ![]() |
Don't shoot the messenger sir... I know not why they would not cover this? or indeed if i was being fed the correct information! Cheltenham Heritage MD were the dealership that told me i should ready myself for the bill if & when warrenty rejected it! They could have been feeding me a croc of |
Aspentree Member Since: 05 Jan 2020 Location: Aberdeenshire Posts: 4 ![]() ![]() ![]() |
Is it possible to see these pipes by removing the rear wheel and the plastic liners or do you need to remove the exhaust and fuel tank? |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
For someone with no technical mind whatsoever ... Where do you look to see this? And do you need to remove anything? I've started getting the "low coolant" warning and this seems an obvious place to look. That said, the car had it's oil cooler replaced before I bought it, so it could be leaking round there. What do I put here then? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I would start by topping up the coolant with the correct type, then monitor and fill for a week or so of normal driving. It’s possible that when the cooler was changed the system wasn’t bled properly and you are seeing the system bleed itself….. failing that start looking for the rear coolant pipe…..
Thanks for the tip.
All sorted by the lovely people at Langley 4x4
Tommybuk Member Since: 17 Jan 2024 Location: Ellon Posts: 13 ![]() ![]() ![]() |
I had the same leak at the rear, from these crappy ally pipes on my 2016 4.4. Fixed for £50.
HenryFrancis Member Since: 28 May 2023 Location: York Posts: 12 ![]() ![]() ![]() |
Hijacking this topic as I have the exact same issue...I hope you guys don't mind.
If it's the same pipe leaking as mine, it goes to the rear heater unit which is in the left side of the boot behind the carpeted panel.
