![]() | Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles |
| lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59
Thanks Chris why didn't you blank and delete them? 2009 TDV8 3.6 |
| chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479
Hi
Thanks for clarifying. 2009 TDV8 3.6 |
| stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64
Just had a good read through this thread. Only seems to mention the 3.6. Are the 4.4's not affected? 2011 Vogue SE TDV8 |
| PeeJayBee Member Since: 04 Feb 2011 Location: Halifax Posts: 7
Hi, I blanked my Egr valves using a similar kit over a year ago without any EML. The Egr will still open and close as normal so the ECU is happy, however I am now starting to get occasional Egr codes and "restricted performance" messages. However the car still runs sweetly and no noticed lack of performance. I guess the egr valves are now needing replacement. I am looking to delete them from the software instead which should stop them moving at all. Any recommendations for software delete? I have a GAP iiD tool. I believe you can get the engine Map off and email for delete. Anyone done this? or advise how? |
| ultron Member Since: 13 Nov 2018 Location: Hamburg Posts: 23
hi,
The 4.4 has a DPF as well as EGR, and you cant blank them off because of that, so blanking only ok on 3.6 |
| jonty88 Member Since: 04 May 2021 Location: Derbyshire Posts: 5
It’s quiet on hear regarding the remapping and deletion of EGRs on the 4.4. People mention that EGRs are required when you have DPFs however I believe this is a misconception …. EGRs lower the combustion temp through a slightly less efficient combustion as a result of less O2 available which reduces the NOx but at the same time actually increase particulates as a result which are captured by the DPF.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Durham Remaps can do it all in house Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 68
I'd be very interested to know this also. I have blanked the EGR's on my 3.6, which improved running dramatically, but I still have the fault. So I want to do the delete, but my car is fitted with dpf's, so I want to be sure I won't do any damage. Thanks, Henrik |
My 3.6 is showing a left bank EGR fault, and giving me loads of restricted perfromance warnings. They go away if you don't clear them, but I need to get a map. 2009 TDV8 3.6 |
| Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 714
If you couple up an OK EGR to the EGR electrical connector, you can delete the fault codes of a faulty EGR without replacing the faulty original if its already blanked & you feel like saving some time. Paul,
Thanks will see if I can find one on ebay. Although I can clear the code it comes straight back, I might have to leave the good one plugged in or swap it over? 2009 TDV8 3.6 |
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
Just blanked out mine using flat plates that retain the corrugated steel pipe, totally stealth. As I have not really driven the car I have no reference point but do think the tick over on startup is now solid where before it was a little lumpy. https://www.ebay.co.uk/itm/121107007210?ha...Sw3PBhJNn4 2007 TDV8 VSE
| All times are GMT |
