Home > Maintenance & Mods (L322) > EGR Delete photos ( update +1300miles) more miles
Page 11 of 12 <123 ... 101112>
lostinespace
United Kingdom 2009 Range Rover Vogue SE TDV8 Zambezi Silver
Thanks Chris why didn't you blank and delete them? 2009 TDV8 3.6
Post #594361 16th May 2021 8:25am
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Hi
They’ve been blanked for the last couple of years but the fault became an issue, as MOT date was approaching.
Yes I could’ve had them deleted but I wanted to be able to put things back to standard when I come to sell the car. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #594362 16th May 2021 8:37am
lostinespace
Thanks for clarifying. 2009 TDV8 3.6
Post #594366 16th May 2021 9:01am
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Just had a good read through this thread. Only seems to mention the 3.6. Are the 4.4's not affected? 2011 Vogue SE TDV8
Post #594465 17th May 2021 8:14am
PeeJayBee
2010 Range Rover Vogue SE TDV8 Alaska White
Hi, I blanked my Egr valves using a similar kit over a year ago without any EML. The Egr will still open and close as normal so the ECU is happy, however I am now starting to get occasional Egr codes and "restricted performance" messages. However the car still runs sweetly and no noticed lack of performance. I guess the egr valves are now needing replacement. I am looking to delete them from the software instead which should stop them moving at all. Any recommendations for software delete? I have a GAP iiD tool. I believe you can get the engine Map off and email for delete. Anyone done this? or advise how?
Post #594484 17th May 2021 11:26am
ultron
Germany 2008 Range Rover Vogue TDV8 Java Black
hi,
try it here .... https://bellautoservices.co.uk/
sebastian
Post #594504 17th May 2021 2:11pm
PeeJayBee
The 4.4 has a DPF as well as EGR, and you cant blank them off because of that, so blanking only ok on 3.6
Post #594505 17th May 2021 2:12pm
jonty88
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
It’s quiet on hear regarding the remapping and deletion of EGRs on the 4.4. People mention that EGRs are required when you have DPFs however I believe this is a misconception …. EGRs lower the combustion temp through a slightly less efficient combustion as a result of less O2 available which reduces the NOx but at the same time actually increase particulates as a result which are captured by the DPF.
Come regen time the car needs to increase its combustion temp momentarily to increase the temp of the DPF and this is done by a number of means including closing the EGR allowing a much cleaner and hotter burn….. pretty sure I’ve remembered this correctly from my Uni Professor who was teaching the ICE module. In theory, when the EGR is blanked the engine creates less particulates and actually places less demand in the DPF.
Has anyone come across any definitive definition of the EGR/DPR relationship that isn’t a forum post or back street tuner website?
I would like to get the EGR mapped out on my 4.4 and I believe lots of cars have had this done and kept the DPF with no issues.
Post #597209 11th Jun 2021 10:13pm
jonty88
Has anyone come across any definitive definition of the EGR/DPR that isn’t a forum post or back street tuner website?
Post #597210 11th Jun 2021 10:13pm
DrRob
Durham Remaps can do it all in house Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #597222 12th Jun 2021 7:23am
Henrik07
Norway 2007 Range Rover Vogue TDV8 Santorini Black
I'd be very interested to know this also. I have blanked the EGR's on my 3.6, which improved running dramatically, but I still have the fault. So I want to do the delete, but my car is fitted with dpf's, so I want to be sure I won't do any damage.
Thanks,
Henrik
Post #605035 28th Aug 2021 1:11pm
lostinespace
My 3.6 is showing a left bank EGR fault, and giving me loads of restricted perfromance warnings. They go away if you don't clear them, but I need to get a map. 2009 TDV8 3.6
Post #605042 28th Aug 2021 2:08pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
If you couple up an OK EGR to the EGR electrical connector, you can delete the fault codes of a faulty EGR without replacing the faulty original if its already blanked & you feel like saving some time. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #605072 28th Aug 2021 6:30pm
lostinespace
Thanks will see if I can find one on ebay. Although I can clear the code it comes straight back, I might have to leave the good one plugged in or swap it over? 2009 TDV8 3.6
Post #605073 28th Aug 2021 6:31pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Just blanked out mine using flat plates that retain the corrugated steel pipe, totally stealth. As I have not really driven the car I have no reference point but do think the tick over on startup is now solid where before it was a little lumpy. https://www.ebay.co.uk/itm/121107007210?ha...Sw3PBhJNn4 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #609688 19th Oct 2021 10:52am
