![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351
Can someone please post an IID screen shot of "normal" and "during an active regeneration burn" of the temperatures against the relevant sensors (Bank 1, Sensors 1, 2 and 3).
Thanks. Was yours working properly when that was taken or having issues?
| dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450
I was trouble shooting an issue at the time but from what I can recall, I've only ever seen temps of 600+ on bank 1 sensor 3.
Glad you concur |
OK, this is non scientific but looking at the WM, I would guess (and it's only a guess) that the sensors are as follows :
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Rob,
Thanks |
| knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782
I appreciate that this is a L322 thread, but for reference, this L405 video I posted recently may be of use to someone...
Rob,
| KM Member Since: 07 Jul 2017 Location: Yorkshire Posts: 11 |
Just to reiterate my own experience with a 16MY L405....
Just an iid update.
Hi Mike, any news on when the DPF regen option is coming to the IID tool? 2011 TDV8 Vogue SE |
| SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114
Not had the issue for a number of years. Travelled from Cornwall towing at the weekend 50-60mpg all the way. Went out today and amber light came on, put some fuel in, and took it for 2 runs of about 20 miles each way. Had to drop to 30mph roads after the 20 miles, and had a stop of around 20 mins before coming back. Would a longer run work? |
Ideally if you can get a run at around 55 60 MPH uninterrupted for 30 mins then your amber should go out (set cruise if you can). If the amber remains after this it may indicate an issue so check the usual suspects such as the 4 hoses on the intake plenum, give the MAP sensor a clean etc. 2011 TDV8 Vogue SE |
