Home > Technical (L322) > Where did that cloud of smoke come from? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
It's going into a second indie as first only did a regen then said "it's fixed". We said but they said it's fine. Avoid them.
15th Jun 2021 8:58am |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 |
Good luck with the latest Indy Rob, I hope they can get to the bottom of things. Incidentally, I sent Pat @ GAP an e-mail to try and get some details on what sensor on bank 1 should have what approximate temperature readings during a regeneration but the reply was inconclusive in that he reported that the IID tool only displays what it is given by the ECU 2011 TDV8 Vogue SE |
15th Jun 2021 12:51pm |
We are NOT seeing upwards of 600 as others do on Bank 1 Sensor 2 when it attempts a burn with high soot levels (over 20).
15th Jun 2021 2:52pm |
Currently at Henshall Engineering in Cheshire for diagnosis as it's still not working properly.
18th Jun 2021 3:01pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3058 |
Rob, iirC in my case, Steve at T&S Norman monitored an internal engine temp sensor in order to discover that the engine was too cool to initiate and maintain regens.
18th Jun 2021 5:30pm |
We should know in the next couple of days the full diagnosis. They are methodically going through things step-by-step ....unlike the previous indie that looked at it and simply did a forced regen Future customer? Nope. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Jun 2021 7:58am |
Update:
2nd Jul 2021 8:18am |
Update from mine Rob :
5th Jul 2021 2:58pm |
Update:
6th Jul 2021 1:33pm |
Thanks for the update Rob, hoping you find a solution as it may help me too 2011 TDV8 Vogue SE |
6th Jul 2021 1:39pm |
It's either a fix or We Buy any Car
6th Jul 2021 3:14pm |
I'm not that far behind you, might even look at buying a box of Swan Vesta if I can't find a solution 2011 TDV8 Vogue SE |
6th Jul 2021 3:34pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Just a question, do the glowplugs play any part in a dpf regeneration on your cars? |
6th Jul 2021 4:48pm |
From what I have read in the Workshop Manual, the glow plugs are not activated during any of the regeneration cycles. 2011 TDV8 Vogue SE |
7th Jul 2021 7:36am |
