Home > Technical (L322) > activate starter code......
Page 2 of 4 <1234>
mjdronfield
This says to lock and unlock car after battery reconnection.....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #601161 19th Jul 2021 6:21pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Many Thanks can try the lock to lock but without the engine on , a bit of a challenge.
Post #601171 19th Jul 2021 7:27pm
alfapat
Weegie wrote:
Just a thought, if you have a Gap iiD, look in the CCF for the BCU to see if there is the option to have the system switched on or off.
Struggling to think of anything else. Sad
Tried that now but nothing in there to help.
Post #601181 19th Jul 2021 8:54pm
alfapat
mjdronfield wrote:
This one takes about touching the terminals together before you connect the battery back up.....
https://www.cargurus.com/Cars/Discussion-t30708_ds543253
Tried the hard reset , but can try again
When you to re-connect the alarm loves it , so I lock unlock but nothing changes.
Post #601182 19th Jul 2021 8:59pm
mjdronfield
Sorry mate, right out of ideas now..... was Googling on my lunch break....
Hopefully someone will come along with more ideas.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #601189 19th Jul 2021 10:10pm
alfapat
Many Thanks
Post #601215 20th Jul 2021 9:25am
alfapat
I put in what is regarded as an default code 1515 to the central screen and not worked for me . Land Rover not helpful with default code either. Tried reset with battery - off and wait a minute , put lead back on and Alarm goes , cancel this and run instructions for 10mn countdown wit key on 11 position. Nothing!
Post #601526 22nd Jul 2021 9:14pm
alfapat
I am stuck, really stuck, I have come across this in the GAPIID Manual ,
I need some advice as to how I get into the sector I am about to post from the Gap Manual, please.
Deactivate Valet Mode (L322-10, L319-10, L320-10) This routine will return the vehicle from valet to normal mode. This is useful when the PIN is unknown and the vehicle is in valet mode
Please advise the process don't seem to find the path!
Post #602133 28th Jul 2021 10:45pm
mjdronfield
It’s not valet mode, that’s on later cars. Yours is BMW based and it’s the user code for the starter immobilisation. In valet mode, the car will still start, I think it locks the glove box and boot etc so valet man can’t search the car.
I wonder if Navcoder will help?
Or it still might be worth emailing GAP or sending a PM, see if they can help via the IID tool.
I also wonder if you might be better with a BMW specialist, as that’s what all the units and electronics are.
Not very often we get stuck on here, but I’ve no idea now. I know what it’s doing, just don’t know how to get you going again.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602147 29th Jul 2021 9:00am
alfapat
Many thanks for your support on this , it's not me that is wrong then, I thought my diagnostic skills were bad but not that bad! I have tried to email GAP last night but the sight froze, frustrating! I'm wandering if GAP Pro might do it.
Post #602150 29th Jul 2021 9:24am
mjdronfield
I think you need to talk to GAP first. I know on a number of occasions they have written code to help on a number of situations and sent it to your IID tool..... but if they can’t or it won’t do anything as standard, might be better to get it going before you invest in one.
I don’t think it’s a specific Land Rover issue, it’s a BMW thing, and there are more BMWs out there with this system in than L322s, that’s why I figured a BMW guru might suggest more.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602153 29th Jul 2021 9:40am
alfapat
Written! Thumbs Up
Post #602155 29th Jul 2021 9:58am
alfapat
Reply from GAP is can't be done.
That is to say the GAP tool can't override the interlock code. Sad
Post #602171 29th Jul 2021 12:07pm
alfapat
Would anyone with their knowledge know if the Sat Nav is controlling the BCM FOR THE CODE , or is the BCM the problem and not accept the code for this interlock.
Post #602570 2nd Aug 2021 12:19pm
mjdronfield
Had a look and a search in RAVE. I took a photo of the screen....
I’m also not sure what it does if a couple of the ecu’s have lost sync? Red herring perhaps... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #602589 2nd Aug 2021 2:13pm
Page 2 of 4 <1234>
