![]() | Home > Technical (L322) > activate starter code...... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7993 ![]() ![]() ![]() |
This says to lock and unlock car after battery reconnection.....
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
Many Thanks can try the lock to lock but without the engine on , a bit of a challenge. |
Tried that now but nothing in there to help. |
Tried the hard reset , but can try again When you to re-connect the alarm loves it , so I lock unlock but nothing changes. |
Sorry mate, right out of ideas now..... was Googling on my lunch break....
Many Thanks |
I put in what is regarded as an default code 1515 to the central screen and not worked for me . Land Rover not helpful with default code either. Tried reset with battery - off and wait a minute , put lead back on and Alarm goes , cancel this and run instructions for 10mn countdown wit key on 11 position. Nothing! |
I am stuck, really stuck, I have come across this in the GAPIID Manual ,
It’s not valet mode, that’s on later cars. Yours is BMW based and it’s the user code for the starter immobilisation. In valet mode, the car will still start, I think it locks the glove box and boot etc so valet man can’t search the car.
Many thanks for your support on this , it's not me that is wrong then, I thought my diagnostic skills were bad but not that bad! I have tried to email GAP last night but the sight froze, frustrating! I'm wandering if GAP Pro might do it. |
I think you need to talk to GAP first. I know on a number of occasions they have written code to help on a number of situations and sent it to your IID tool..... but if they can’t or it won’t do anything as standard, might be better to get it going before you invest in one.
Written! |
Reply from GAP is can't be done.
Would anyone with their knowledge know if the Sat Nav is controlling the BCM FOR THE CODE , or is the BCM the problem and not accept the code for this interlock. |
Had a look and a search in RAVE. I took a photo of the screen....
