![]() | Home > My Range Rover > New to me UK RR Vogue SE (2012) - Some questions too :) |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Welcome.
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 ![]() ![]() ![]() |
Oh right, I figured it would be the lense doing the projections not the bulb itself, will check. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1342 ![]() ![]() ![]() |
Deffo lenses I would say. My 2nd turbo comes in at about 2500-2600 rpm. Any pictures of your car we can drool over? |
Yes, sorry, I just meant put it back to standard re the puddle lights. I’ve never changed mine, so as above, could well be the plastic lens.
Perfect, I'll give it some of that once it's warm ![]() As for pics, I haven't really properly detailed it yet but I have this one...
And sadly, now this one too....
That last one popped up the day after I got it but then no problems for a few days, reared its head again today, followed shortly by the 30MPH Max alert and then "Forward assist disabled" which I assume is related to the car having no feedback from suspension. |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
It is worth firstly making sure the correct software is installed, I had similar issue and found the compressor had been changed from a Hitachi to AMK by main dealer and not updated. No issues since doing. You will need IID tool.
I’m not sure if it stops the front radar if it can’t guarantee the car is level due to a suspension fault.
It first happened parked on the drive when I hit the access mode button (engine not running) car dropped down but got the bong and amber alert. Turned off ignition, then started the car, no alert and I was able to get back into normal height no problem. The next day it happened I'd parked, entered access mode no problem, got back in the car and it raised no problem, then about 5 minutes later, whilst driving into town I got the ping and the amber warning, followed a free minutes later by the 30MPH ping and then it disabled both the adaptive cruise and the forward assist. Suspension seemed to be moving up and down without issue but cant be 100% sure how quickly it should happen (one thing I note is that is seems to lift the rear, then the front... I assume that is normal). Then for the next few days, no problems with any of those systems. Today it happened and I was locked out of making any height changes (just get a bong from the dash when pressing the height adjust buttons) until I turned the engine off and back on. Then it felt like it was struggling to lift. It almost seemed as though the front rose a little, then dipped a little, then came back up. On the driveway the vehicle raising text was on the screen for a long time and I didn't feel it was moving much. Also seems like the arse end is sitting lower (level across the rear axle but lower than the front). I guess there could be many many reasons for this and without diagnostics its impossible to know what the cause is. Battery voltage is a little low (12.3v), not checked that with the engine running but I think the ideal voltage is 12.4v and no lower than 12v without the engine running. I guess im not as worried as I would be if I didn't have that warranty, still a hassle I could do without with a baby due to arrive in the next few days ![]() |
I guess that makes sense when you think about it ![]() |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4346 ![]() ![]() ![]() |
Take it to Craig at Cam Tech in Gloucestershire. He’s active on here, site sponsor and a guru |
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 ![]() ![]() ![]() |
Nice looking motor |
Good to know, thanks ![]()
They do look stunning, I keep finding myself trying to make an opportunity to go somewhere just so I can drive it ![]() |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
If your LR Warranty is still active (not expired) then get it in while it's still covered. Please note that most garages are booking weeks down the line due to being busy at the moment so get yourself in the diary ASAP 2011 TDV8 Vogue SE |
Fault codes are
