Home > Technical (L322) > Where did that cloud of smoke come from?
Page 11 of 13 <123 ... 10 111213>
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Looking at the new plenum it's clear to see just how split the old one was around the inner seam.
OLD :
NEW:
 2011 TDV8 Vogue SE
Post #602586 2nd Aug 2021 1:49pm
kevinp
Dare I ask how much the new part was?
Post #602593 2nd Aug 2021 2:45pm
dennij
Not cheap that's for sure. I shopped around and the cheapest genuine part I could find was £483.54 This was for the latest incarnation of this part which seems to have been superseded many times over the years. It's a lot of money for a piece of plastic Shocked 2011 TDV8 Vogue SE
Post #602594 2nd Aug 2021 2:49pm
DrRob
Very obvious Bow down
Looking forward to update Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #602600 2nd Aug 2021 4:10pm
dennij
Finally got everything fitted and ready to test. Took it for a drive down the motorway but sad to say the problem is still the same. Engine up to temperature and soot level slowly going up despite sensor 3 reading 615g Sensor 2 stayed around 450c. Oddly whilst monitoring the levels on the way back home I found that whilst driving at 50MPH on an A road that meant stopping at lights and having to drop to 30MPH twice due to speed limit changes, if sensor 2 read a higher temperature than sensor 3 the soot level would drop, albeit only small amounts. I left home at 19.5G and reached 20.6g on the motorway, by the time I got home I was reading 18.1g. So from that I think it proves that something is causing sensor 2 not to get up to temperature. On another note I stopped at a coffee drive through and could smell what appeared to be exhaust fumes? Hard to say exactly but it was definitely something other than unburnt diesel.
Ran faults check and once again had the following as shown below but this fault won’t clear. I am thinking it would be better to spend my money having a brick wall built so I have something to bash my head against
 2011 TDV8 Vogue SE
Post #603117 7th Aug 2021 5:57pm
GGDR
What is your DPF pressure differential v reading ?
At idle and under throttle?
if at idle it is 0.9v then it might be time to have the dpf off and cleaned.
Normal is 0.7v at idle, under acceleration 0.9 to 1.2
Your regeneration is running but for how long was it holding at over 600c ?
Btw the other sensors don't go this high, only the one.
Also best doing regeneration using cruise control and also don't forget 1/4 tank fuel minimum . under 1/4 tank it won't regenerate.
. Cheers, Greg
Post #603136 7th Aug 2021 8:08pm
dennij
Hi Greg many thanks for your response
Volts readings are within tolerance showing 0.757v at idle and just over 1v at 4,000 RPM.
General consensus on here is that bank 1 sensor 2 is the one that should read in excess of 600c, I have that reading but on the wrong sensor which is odd. The highest temperature will hold for a few minutes, possibly 5 before dropping to the high 500’s.
I’ve had the DPF removed and cleaned and sat on the motorway prior to replacing the plenum for an hour at 55MPH on cruise with no success. I was hoping that the plenum being changed would finally give me a proper regeneration, sadly this hasn’t been the case. I’ve had a high pressure smoke test carried out which lead to the passenger inlet manifold being replaced. There are no other errors logged other than the one posted above. 2011 TDV8 Vogue SE
Post #603162 8th Aug 2021 7:41am
GGDR
ok good yes that seems fine - this is effectively is your clog meter.
On my DPF posts there are screen grabs of a regeneration in progress if you want to check the sensor numbers / behaviour.
5 mins isn't right... But it does cycle. Actually the temps go up in steps. 400-odd, then 500-odd, then 600-odd. It will then drop sometimes to 580 then after a minute or two, go back up to around 630c .The whole thing will take 15-20 mins.
ok good, sorry I am sure you have said this, I didn't read back through your thread.
that should certainly be enough. Is it doing what I call "maintenance burns", loosing a few grams.
Next suggestion I think is to get a DA-DPF tool which I bought and use, it's good and it loosens up the regeneration requirements, forcing a regeneration through the ECU. I am told the IID Tool does this now but I've not tried it.
When you had the DPF cleaned, did you reset the DPF on the ECU?
You can do this on the IID.
. Cheers, Greg
Post #603163 8th Aug 2021 7:52am
dennij
The drop from say 620c will go down to around 550c at its lowest but rises again pretty much as you mention going back to 600+c in increments of between 5 & 10c at a time.
You mention maintenance burns, this is exactly what I see except if on the motorway at a constant speed of say 55MPH to 65 MPH ( I’m trying all sorts at the moment) when the soot level will just rise slowly despite the temperatures being at regeneration ones.
I’ve read that the IID tool is looking to have the regeneration option added but haven’t had any news to say it’s now out of the beta phase. It’s certainly something that we could all do with. I will have a read through your post to look at your temperature readings on the sensors Thumbs Up 2011 TDV8 Vogue SE
Post #603165 8th Aug 2021 8:04am
GGDR
So how long is it burning at over 600 ? in total?
. Cheers, Greg
Post #603166 8th Aug 2021 8:12am
dennij
It will burn at 600c for between 5 - 10 minutes at best before dropping to 595, 590, 585, etc down to a low of 550c before climbing back up to a maximum of 620c where the process repeats 2011 TDV8 Vogue SE
Post #603170 8th Aug 2021 8:46am
dennij
Forgot to say Greg that the DPF was reset upon refitting after the clean (Told car it had a new DPF via IIDtool)
Just had a read through your post and it shows that sensor 2 is indeed the one that should be reading in the 600’s
All I need to do now is find out why mine shows these readings on sensor 3 Rolling with laughter
If only it were that simple Big Cry 2011 TDV8 Vogue SE
Post #603171 8th Aug 2021 8:54am
GGDR
if you add up all the 600 burn times ?
because 3 or 4 of those should bring your soot to 5g give or take
if 3-4 of those then the regeneration is actually working as it should.
. Cheers, Greg
Post #603173 8th Aug 2021 9:09am
DrRob
I’ll be providing an update soon on the family friend tdv8 Thumbs Up
My gut feeling dennij is you may not be doing enough longish journeys. Please tell me otherwise Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #603181 8th Aug 2021 10:46am
Dolphinboy
@Rob and Dennis,
I don't think the journey type or length is a factor here. mine has regenned at 30mph and while sitting at the lights!
Dennis your car its displaying EXACTLY the same symptoms as mine (to a tee!!). I have had exactly the same repairs done as you (inlet manifold, DPF clean etc). I think the fact that your car initiates a regen (hence the small reduction in soot) and not completing it means the temps are not being held long enough.
In mine it was the Thermostat housing had been cracked and was open all the time, the sensor over-reading the temps (i.e. Thinking it was hotter than it was in reality, this starting the cooling process erroneously) This meant the fans were always on and the engine temp was too cool. Do your fans seem to come on all the time? Mine hardly ever now.
I would look again at the internal engine temp whilst running and the cooling system/thermostat.
Post #603194 8th Aug 2021 12:59pm
