Home > Technical (L322) > L322 4.4 v8 2005 FBH problems
Sigmundreder
Norway 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi!
I have some troubles with my FBH.
It will only run for 2 min 40 sec give or take.
Sometimes it wont start at all.
Last week i was able to Get to run! For four minutes….
I would like to try and remove the fuse, but i cannot seem to find it.
Is it in the glovebox?
Winter is right around the corner here in Norway, so would love to Get this sorted.
Any help?
Post #607678 29th Sep 2021 1:03pm
Dolphinboy
if it is shutting down before the recommend run time, that can a sign of a weak or low battery. Do a battery test before anything else.
Post #607687 29th Sep 2021 2:01pm
Sigmundreder
Thanks!
I have thought about that, but i tried the FBH when a ctek charger was connected to the battery. And it was 100% charged, still no good.
Post #607688 29th Sep 2021 2:05pm
Gsxr1250dave
Sounds like the usual failed to ignite issue, iv been planning on the fbh conversion on my 4.4 m62. Bought everything tested everything just didn't get a chance to fit it.
You can remove the fbh and give it a service off the car BUT before you do try running an air line into the air intake when you try and fire it up, worked a treat on our D3 the fbh hadn't worked in years. Not sure if the L322 is the same software but on the D3 after to many failed to start it locks out and needs a reset. I'm not sure the L322 is that clever.
Post #607703 29th Sep 2021 4:43pm
Sigmundreder
Great tip! I will try.
But does anybody know where the fuse is located?
The Webasto Thermo top c on my old Defender, fixed it self after a little play with the fuse.
Post #607706 29th Sep 2021 5:02pm
Gsxr1250dave
Yes it is in the fuse box inside the glove box, the fuse is missing from mine so I have to add it to power the feed to the fbh
Post #607709 29th Sep 2021 5:58pm
Sigmundreder
So i took a little look today.
Found fuse 59, and it was there.
Tried pulling it in different sequences, and it does indeed reset it.
But still no luck with that easy way.
After i reset it, it will lunch by pressing the additional fob, for to seconds then shut down.
After that i can not Get it to Even start by using the fob. I first need to press and hold the off button.
When i then start it, it will run for two minutes give or take.
Looks like i have to get it out from the wheelarch.
Post #607882 1st Oct 2021 6:06pm
Gsxr1250dave
This is a standard webasto heated iv a couple in different stages of modification, there are certain conditions that must be met for them to work
1. Minimum quarter tank of fuel
2. Minimum battery voltage
3. No hard faults stored if there are these must be cleared with diag before it will work again. Or that's how they work on the D3/D4 and they are the same units.
I will have a look see on the disco forum or you can pop over and have a look see your self and follow the how to guides .
Post #607886 1st Oct 2021 6:26pm
Sigmundreder
Thanks Dave!
There is enough fuel, and i am sure the battery is good.
I will double check the battery.
But, i am not so sure about previous faultcodes and readings.
My local garage has a real guru that maybe can delete faultcodes if needed.
I think i might drop by him, for a quick test before i remove the Webasto.
Post #607887 1st Oct 2021 6:31pm
Gsxr1250dave
It just doesn't get cold enuf here in the UK for it to have been soecced as an option when new those that have them fitted are a very rare car indeed. On the top gear episode in 2002 when the L322 was 1st launched Clarkson even comment on the small paraffin heater fitted in the wheel arch to warm the car up on the timer before getting into it.
Have a read
https://disco3.co.uk/wiki/Fuel_Burning_Heater
Post #607888 1st Oct 2021 6:33pm
Sigmundreder
Thanks again Smile
I think almost (90%) of all Land Rover products in Norway, both Petrol and Diesel have fitted them.
But the Norwegian Land Rover Club and the associated forum are not that experienced with L322 or L405.
They do know the P38 very well, and the rest of the line up.
Post #607889 1st Oct 2021 6:40pm
Sigmundreder
Does anybody know if its a Webasto Thermo Top C or V? Or a another modem from Webasto?
Post #607893 1st Oct 2021 8:58pm
Sigmundreder
So, i had charged the battery full today.
I fired the FBH up via the fob.
Heard a little splash underneath before it stopped.
(The first time it always starts, and stops after a second).
It just spitted some coolant, but i was not able to find out from where since the ground was pretty wet.
That dont seem normal to me… Laughing
Post #608380 5th Oct 2021 8:14pm
Gsxr1250dave
Defo shouldn't be spitting coolant best have a look see pull the fbh and strip it down the water pumps are known to fail that would cause a no flame condition for sure.
Post #608381 5th Oct 2021 8:22pm
Chris1573
if you take a look at the disco forum they sell a cable you can plug in to test the FBH and you can down load the WTT test software FOC from Webasto.
Lots of info here.
https://lr-fbh.co.uk/wp-content/uploads/20...Manual.pdf L322 2007 TDV8 3.6
Post #608541 7th Oct 2021 9:15am
