![]() | Home > Technical (L322) > L322 4.4 v8 2005 FBH problems |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3239 ![]() ![]() ![]() |
if it is shutting down before the recommend run time, that can a sign of a weak or low battery. Do a battery test before anything else. |
Sigmundreder Member Since: 29 Sep 2021 Location: Oslo Posts: 36 ![]() ![]() ![]() |
Thanks!
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1026 ![]() ![]() |
Sounds like the usual failed to ignite issue, iv been planning on the fbh conversion on my 4.4 m62. Bought everything tested everything just didn't get a chance to fit it.
Great tip! I will try.
Yes it is in the fuse box inside the glove box, the fuse is missing from mine so I have to add it to power the feed to the fbh |
So i took a little look today.
This is a standard webasto heated iv a couple in different stages of modification, there are certain conditions that must be met for them to work
Thanks Dave!
It just doesn't get cold enuf here in the UK for it to have been soecced as an option when new those that have them fitted are a very rare car indeed. On the top gear episode in 2002 when the L322 was 1st launched Clarkson even comment on the small paraffin heater fitted in the wheel arch to warm the car up on the timer before getting into it.
Thanks again |
Does anybody know if its a Webasto Thermo Top C or V? Or a another modem from Webasto? |
So, i had charged the battery full today.
Defo shouldn't be spitting coolant best have a look see pull the fbh and strip it down the water pumps are known to fail that would cause a no flame condition for sure. |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
if you take a look at the disco forum they sell a cable you can plug in to test the FBH and you can down load the WTT test software FOC from Webasto.
