Home > General > What Did You Do In Your Full Fat Today
Page 341 of 385 <123 ... 340341342 ... 383384385>
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Went shooting in Oxfordshire and filled up on the way. On the return journey no fuel at any motorway services. Sort it out BoJo…..
Post #607417 26th Sep 2021 3:57pm
Gsxr1250dave
Filled up with LPG good for another 250 miles at half price motoring
Post #607469 26th Sep 2021 8:48pm
Gsxr1250dave
A new Teflon O ring for the air pump, all fitted 20 min job prevention better than cure
Post #607570 28th Sep 2021 11:05am
Weegie
Gearbox plastic sump and ZF6 fluid, transfer box and front and rear diffs oil change. John
GAP iiD BT-Sold
Post #607867 1st Oct 2021 3:20pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Joined the egr-less gang with my 2007 TDV8 Vogue. Mr. Green Now immediately responsive. No part throttle shudder. Bit more noise I think.
Fitting went well - just over an hour or so but I like to take my time. The removed pipes were mucky but not dreadfully so for a 130k mile car. I will retrieve one of the support bracket bolts when I next remove the undertray! Embarassed Started right up and no warning light. Cool
Mpg was previously pretty fair so if there's any improvement that would just be a bonus. 30 mile test drive went well. All good!
Chris
Post #607960 2nd Oct 2021 6:34pm
JayGee
Pulled the map sensor from the intake 'dounut'
A good blast with brake cleaner cleared it and I'm absolutely certain it picks up a lot more quickly and smoothly now. 2012 TDV8 Vogue (L322)
Post #608022 3rd Oct 2021 12:14pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Changed the passenger side door lock and repaired the door card which was falling apart... Some heavy duty adhesive and it's all sturdy and quiet Thumbs Up
Post #608027 3rd Oct 2021 12:40pm
Weegie
Had new left EGR valve fitted. John
GAP iiD BT-Sold
Post #608483 6th Oct 2021 3:56pm
JayGee
Terrible wind noise while driving on the M-Way and looked at the back of the glass and it was down. After searching here I did a sunroof reset and it's now level! 2012 TDV8 Vogue (L322)
Post #608554 7th Oct 2021 2:42pm
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Towed my race car to Castle Combe & back for a track day
Post #608557 7th Oct 2021 4:00pm
JayGee
Raised the suspension, crawled underneath and removed the side steps ( 5 min job). Nice clean lines and shape now restored! 2012 TDV8 Vogue (L322)
Post #608728 9th Oct 2021 3:03pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Installed the heated/cooled seat repair kit of the group buy in the driver seat. As I removed the seat now for about the 5th time it was an easy and quick job of 30 minutes.
Post #608730 9th Oct 2021 3:52pm
DrRob
Filled up Laughing
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #608732 9th Oct 2021 4:44pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Sold it to RouseyD.
Hope you enjoyed the drive home Dave.
Now to start the look for the replacement. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #609390 16th Oct 2021 4:07pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Not today, but last week.
Three days work. New timing chains, tensioners and guides.
Running very, very smooth again Very Happy
Post #609402 16th Oct 2021 6:22pm
