Home > Maintenance & Mods (L322) > Main beam L322 Final Series
Page 2 of 3 <123>
Klunk
mjdronfield wrote:
Fitted a pair of some Night Eye ones. As above, 10 mins to fit.
Obviously not been out in the dark yet, but in a garage with the interior light off, I couldn’t see any flickering when ignition was turned on.
Much better white light. See how we go….
Kept the originals of course…..
How many bulbs per side?
Are they H4 ?
Aren’t the factory HIDs Bixenon ? I am confused what function these perform …
Post #607987 2nd Oct 2021 10:50pm
mjdronfield
My headlights are the same, bi-xenon… you don’t touch them. This is the other little light that’s in the headlight unit… it’s halogen and used with full beam xenons and when you flash the lights. Xenons no good for flashing as take about 3 Seconds to warm up……
They are H7…..
As per first pic in the thread, the ones marked A… just 1 bulb per side.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #607988 2nd Oct 2021 11:34pm
Klunk
Thanks, how do the new bulbs suit the xenons colour wise ?
Also re Bixenon i thought they used a shutter rather than a second bulb - so the halogen could only be to bridge the gap between initial on and 3 seconds later ..
Post #608009 3rd Oct 2021 10:51am
the xenons do indeed use a shutter to flick from dip to main...the H7 bulbs are for flashing and giving extra light when on main beam.
H7 bulbs come in different temperatures giving different 'colours' as do the xenon bulbs ..
the standard OE bulbs are 4300k which gives a yellow light..
if you want a whiter light then replace both with 6000k type bulbs.. ... - .- -.
Post #608015 3rd Oct 2021 11:33am
Klunk
Thanks, 4300 is the colour temp of sunlight i think - or near to it. The headlights are the best i have had on any car I think.
Bloody amazing on the welsh roads in the dark.
Post #608023 3rd Oct 2021 12:23pm
mjdronfield
As Stan says, the halogen lights are like the spot lights you’d have fitted in years gone by. To be fair, colour wise, I can’t believe how close my new bulbs are to the xenons.
Get a pair bought, less than £20 and you get the instant on that LEDs provide and more light. Ideal for dark Welsh lanes.
I thought about doing the fog lights, as they are yellow, but given you drive with those on with cars in front of you, and I’m not sure brighter light is what’s needed in fog, I’m going to leave them as they are.
I’ve found some amber LED side indicator bulbs that I’m going to try. Don’t know why they didn’t fit them from factory…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #608030 3rd Oct 2021 1:14pm
Klunk
Yep have bought some, i fitted an LED interior bulb set and i love the difference.
Post #608070 3rd Oct 2021 5:34pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Aren't H7's 55W? Those appear to be 80W does that present any problems? Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #608181 4th Oct 2021 2:39pm
Klunk
With LEDs they normally post wattage equivalent.
Most of my home LED bulbs are 5-10 w with an equivalent of 60-100w incandescent
So it’ll be less wattage than 55w with more light output that incandescent.
Post #608192 4th Oct 2021 3:36pm
mjdronfield
Yes, they take up much less power than normal/old style bulbs, hence why you need to try and get Canbus error free ones, or the car thinks the bulb is blown and throws up bulb failure messages as so little power is being consumed.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #608193 4th Oct 2021 3:41pm
rvbush
Good point, my brain obviously failed there, think how powerful 80W LED's would be!
I'm going to try a pair and see how they go. Assume they don't throw up any errors? Drives:
Post #608287 5th Oct 2021 9:48am
mjdronfield
No errors on the ones I bought…
https://www.ebay.co.uk/itm/371786510808?mk...ded1a4f103
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #608297 5th Oct 2021 10:28am
Michiganstar
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
double post
Post #608300 5th Oct 2021 10:49am
Michiganstar
I put some 10k lumens ones I found in the garage. No error and very very bright!
Checked the D3S headlight bulbs whilst I was there and they need replacing so thats next on the list.
Post #608301 5th Oct 2021 10:50am
Michiganstar
Couple of shots out from earlier. Low beam/high beam.
Post #608390 5th Oct 2021 8:58pm
Page 2 of 3 <123>
