Home > Maintenance & Mods (L322) > Main beam L322 Final Series |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7634 |
My headlights are the same, bi-xenon… you don’t touch them. This is the other little light that’s in the headlight unit… it’s halogen and used with full beam xenons and when you flash the lights. Xenons no good for flashing as take about 3 Seconds to warm up……
2nd Oct 2021 11:34pm |
Klunk Member Since: 12 Jul 2021 Location: North wales Posts: 72 |
Thanks, how do the new bulbs suit the xenons colour wise ?
3rd Oct 2021 10:51am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
the xenons do indeed use a shutter to flick from dip to main...the H7 bulbs are for flashing and giving extra light when on main beam.
3rd Oct 2021 11:33am |
Thanks, 4300 is the colour temp of sunlight i think - or near to it. The headlights are the best i have had on any car I think.
3rd Oct 2021 12:23pm |
As Stan says, the halogen lights are like the spot lights you’d have fitted in years gone by. To be fair, colour wise, I can’t believe how close my new bulbs are to the xenons.
3rd Oct 2021 1:14pm |
Yep have bought some, i fitted an LED interior bulb set and i love the difference. |
3rd Oct 2021 5:34pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 520 |
Aren't H7's 55W? Those appear to be 80W does that present any problems? Drives:
4th Oct 2021 2:39pm |
With LEDs they normally post wattage equivalent.
4th Oct 2021 3:36pm |
Yes, they take up much less power than normal/old style bulbs, hence why you need to try and get Canbus error free ones, or the car thinks the bulb is blown and throws up bulb failure messages as so little power is being consumed.
4th Oct 2021 3:41pm |
Good point, my brain obviously failed there, think how powerful 80W LED's would be!
5th Oct 2021 9:48am |
No errors on the ones I bought…
5th Oct 2021 10:28am |
Michiganstar Member Since: 30 Sep 2021 Location: West Berkshire Posts: 12 |
double post |
5th Oct 2021 10:49am |
I put some 10k lumens ones I found in the garage. No error and very very bright!
5th Oct 2021 10:50am |
Couple of shots out from earlier. Low beam/high beam.
5th Oct 2021 8:58pm |
