Home > Maintenance & Mods (L322) > Locked out of my 2011 RR Vogue
Page 3 of 3 <123
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Thanks for your suggestions guys, shall try vs322 option. -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #609367 16th Oct 2021 11:51am
Giffer2018
Latest update for you guys.
Yipee! managed to get in without breaking a window (now got a spare second hand one). Alarm did not go off, released bonnet catch.
Disconnected battery, left it for half an hour, reconnected it alarm went off, pressed fob button alarm stopped all doors unlocked. Tried locking/ unlocking all works ok. Started up, turned steering lock to lock, took for run drives ok.
Checked alternator charging ok when ticking over, so I must have flattened battery while working on RR.
Had a look a battery size, it has been fitted with a Lion 017 type before I bought RR. So have just got a new one today an Exide 019 EK950 AGM for a very good price, see link.
https://batterygroup.co.uk/Batteries-By-Ap...gIicvD_BwE
Will fit battery when it stops raining and remove door panel to find out why emergency key does not work.
Very happy that I have not had to send it to dealers at great expense and inconvenience, as per breakdown companies solution. A Yorkshire man does not like to be beaten. -----------------------
Post #609614 18th Oct 2021 5:19pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Great news! Perhaps you could now use some inexpensive monitoring solution to rule out battery drain.
Post #609617 18th Oct 2021 5:28pm
mjdronfield
That’s good then. Bad things happen when the battery goes flat, and better to have the correct one fitted.
Won’t ask how you got in on here 🤣.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #609618 18th Oct 2021 5:28pm
Fox889
Congrats, boy done well! Laughing 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #609626 18th Oct 2021 5:58pm
Giffer2018
Just to update you all.
Removed passenger door panel etc(seeing sun was shining), emergency lock barrel turning inside door but not doing anything.
After removing piece of thin foam covering top of door lock mechanism and having a look with my endoscope camera. I could see a four pointed socket in the top of the lock that should have had the end of the lock barrel in it. So slackened the lock barrel from door and with a fair bit of jiggling inside door panel, got the barrel shaft to fit in the correct place. The door now unlocks with the emergency key.
I would suggest that you all check your key works for peace of mind, so you do not get problem I had.
Thanks again for all the help. -----------------------
Post #611477 3rd Nov 2021 12:11pm
mjdronfield
Nice one. Got there in the end.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #611481 3rd Nov 2021 1:01pm
Page 3 of 3 <123
