![]() | Home > Technical (L322) > Parking assist system stopped working |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
i had this with my old westie ..turned out to be a faulty parking aid module in the rear near side cubby.. ... - .- -.
| bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344
Exactly the same symptoms as I had. After spending hours dismantling both front and rear bumpers to check the sensors, which were all fine, I bought a used module for £99 and fitted it in about 2 minutes flat. No more problems. |
| JayGee Member Since: 27 Jul 2021 Location: London Posts: 3403
Fuse is good so ECU it is then - presume they are all the same? 2012 TDV8 Vogue (L322) |
2012 it's not behind the fuse box on the right but low down in the left load space compartment
thats what i said, rear near side... ... - .- -.
Thanks - should have read carefully before looking at youtube videos...... 2012 TDV8 Vogue (L322) |
Can't work out what is the right part for this. Seems it's a common component on JLR and Fords. I suspect the key code is '15k866' but can't be 100% sure and there are no items I can find with the exact codes I have. 2012 TDV8 Vogue (L322) |
Swopped out the ECU but system still dead - any fault tracing diagnostic procedure out there or even a circuit diagram? 2012 TDV8 Vogue (L322) |
WSM is in the Wiki.
Thanks. I'm pretty sure it's the ECU as when I pulled it apart there was some green Verdigris on the bottom of the board so some water must have got in there at some point. Also I'm assuming as the switch light doesn't even illuminate that it's not a sensor or sensor wiring problem. Really need to get this fixed so may have to pony up £200 for a new ECU as there are none with that part number on Ebay. 2012 TDV8 Vogue (L322) |
| RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 208
https://www.gentlemenofsalvage.co.uk/produ...7923065916 (listed as out of stock but call for availability), suppose a call might yield results
Many thanks - will make an enquiry. 2012 TDV8 Vogue (L322) |
You'll get a forum discount from Duckworths - drop them a message. |
2 used a brand new module later and the switch now at least flashes. Too dark to do any more investigating but next job is sensors and wiring..... 2012 TDV8 Vogue (L322) |
| All times are GMT |
